LM-1 Logging Issue
Old Jun 19, 2009 | 08:27 AM
TouringBubble's Avatar
LM-1 Logging Issue
Guys, I thought I'd start here for help since there is knowledge of EvoScan in this forum.
Basically, my LM-1 just decided to stop logging to EvoScan. I'm still using .99, but have also tried other, newer versions of the software with the same results.
The COM port is correct, the PC sees the device connected. I've tried selecting LM-1 and LC-1 from the menu in EvoScan.
Basically, I can select Wideband to log and EvoScan logs perfectly, just with blank cells for the WB. I get no errors. the LM-1 displays the AFR and lambda correctly on the screen and records correctly as well.
This is a portable kit, so I'm using the 12v adapter in the cigarette lighter and the Innovate exhaust clamp for the sensor itself.
Any input would be awesome. Thanks.
Old Jun 19, 2009 | 08:30 AM
Fast_Freddie's Avatar
Veteran: Navy
Go into the LM programmer and see what the fuel setting is and make sure it is set for gasoline 14.7 and not custom. For some reason the innovate stuff will just go random and haywire every now and then and do its own thing...
Old Jun 19, 2009 | 08:43 AM
Ah, good call.
Another note. I did try to log it in the Innovate software and could not connect to it or log. I'll revisit that and see if I can recalibrate it.
Old Jun 19, 2009 | 10:59 AM
Veteran: Navy
Check the "headphone" jacks where the serial out connects to and make sure that the shorting plug is installed in the input plug...
Old Jun 19, 2009 | 12:20 PM
There are no 1/8" connections on the LM-1. This one has the box that controls everything. So, the sensor and power go to the box and then I go from the box to the computer.
But, since you've mentioned the LC-1 ... the LC-1 installed int he car still logs fine, so i don't think it's a EvoScan issue, but an LM-1 issue.
logic's Avatar
This is a similar problem to one I was having: EvoScan would log "invalid" values, at a rate of two or three for every "good" sample. If I normalized those out of the displayed log, the results looked fine: not a lot of resolution, but they appeared to be accurate.
Logging via LogWorks, and via the analog output through the ECU, has and continues to work just fine. In fact, with DMA logging, it's far superior.
I suspect something's not quite cooked with EvoScan's Innovate bus support, for some reason, but since I have a workable solution, I didn't really spend any time on it. My results were with whatever the latest beta of 2.6 Hamish posted recently was.
Old Jun 19, 2009 | 12:21 PM
Oh, I've also tried 2 different Serial > USB adapters and neither worked.
Old Jun 19, 2009 | 07:08 PM
batdorf9's Avatar
I have pretty much the same setup as you and it works. EvoScan .99 and an old LM-1. However, I'm using a Serial to USB converter. All this works fine for me.
I wish I could be more helpful in debugging your problem. I don't really have any ideas though.
So it was working before and then now it doesn't work?
Old Jun 22, 2009 | 07:34 AM
Yeah. It worked fine before and now it doesn't. I'm leaning toward a damaged serial cable. I still haven't tried to verify the fuel setting though.
I just think it's very strange that I don't get an EvoScan error with this thing not functioning. Just a blank column.
Old Jun 22, 2009 | 09:00 AM
Veteran: Navy
I am telling you, open up LM programmer and see what the fuel setting is, and make sure it is set to gas 14.7, and not custom.
Old Jun 22, 2009 | 11:04 AM
I'll do that today ... I've just been bust with other stuff and haven't had a chance. Thanks again.
Old Jun 22, 2009 | 11:07 AM
SLO-EVO's Avatar
is the LM Programmer picking up the signal from the wideband itself? Which error message are you getting?
Swinkndan
Nov 17, 2011 06:32 AM
infini_IV
Apr 17, 2011 08:19 AM
AlwaysinBoost
Sep 6, 2010 06:29 PM
SoCalRedLine
Mar 12, 2009 04:22 PM
nj1266
Jul 7, 2007 08:39 PM
