Innovate LC-1 Compatible USB to Serial Converters
Old Jan 29, 2007 | 05:49 PM
recompile's Avatar
I'm hoping to pick up an LC-1 Wideband real soon, I just want to make sure I'll have a working USB to Serial converter before I do.
I currently have a Belkin PDA Adapter that is setup on COM2, I have no idea if this will work (Model # F5U109)
If you have an LC-1 and are using a USB to Serial adapter, could you please post which one you're using?
Thanks, in advance!
Old Jan 29, 2007 | 06:09 PM
jfitzpat's Avatar
FWIW, I've tested with most of the common chipsets. Personally, I use a couple of Sewell adapters (which are based on the Prolific stuff), a no name from Radio Shack (that uses a Silicon Image chip), and an eval unit from FTDI.
-jjf
Old Jan 29, 2007 | 06:10 PM
recompile's Avatar
So you haven't encountered one that DIDN'T work ?
Old Jan 29, 2007 | 06:39 PM
alex4nder's Avatar
I use the Keyspan 19-series USB<->RS232C adapters, and they work well with everything (including the LC-1).
Old Jan 29, 2007 | 11:15 PM
jfitzpat's Avatar
On XP, no.
-jjf
Old Jan 30, 2007 | 04:28 AM
recompile's Avatar
Thanks again!
hashaam81
Jun 17, 2014 10:09 AM
parralegend
Feb 18, 2013 02:35 PM
SudzRA
May 18, 2011 09:28 AM
FlintownKilla
Mar 9, 2009 07:58 AM
jason4656
Oct 4, 2007 04:43 AM
