changes in fuel map does not have effect . why ?
Old Jun 23, 2009 | 03:45 AM
tkklemann's Avatar
Log your O2 lambda readings and convert them to AFR to see if it is anywhere even close to what the LC1 is saying, just as a reality check to see if the LC1 is reading properly.
Old Jun 23, 2009 | 06:21 AM
ms_logging's Avatar
on idle my lc1 shows 14.5-14.7 i think its close to reality. but i will try.
Old Jun 23, 2009 | 06:23 AM
tephra's Avatar
^ dont fall into that trap.
widebands will deviate futher from the actual AFR the futher they are from stoich!
Old Jun 23, 2009 | 06:54 AM
ms_logging's Avatar
ok. can you tell me more about how to check my wideband readings ? explain me what to do please.
Old Jun 23, 2009 | 08:28 AM
evo8426's Avatar
you need to recalibrate the wideband and then log and see if the numbers stay the same or not
Old Jun 27, 2009 | 01:41 AM
ms_logging's Avatar
problem solved i don't know how but after i have changed ignition maps everething goes ok now. changes take efect . and i have disabled lean spoolup. maybe this helped ?
Old Jun 27, 2009 | 02:52 AM
Evo_Jay's Avatar
Originally Posted by ms_logging
hi all ! my car is stock evo 9 mr . cat deleted and running 1.3 bar boost. (modified restrictor near the turbo). when i make changes on WG map ignition map and others there is some changes aplyed. but when i tryed to tune fuel map and monitoring result with innovate wideband the result was always the same . after 5000rpm goes 10.7 and after 6500 goes 10.2 . any ideas ? thanks !
You know that 1.3 bar of boost is only 18.85 psi, which is lower then stock??
Maybe you should read one of my how-to's on controlling boost with ECUflash and the stock boost solenoid.
Old Jun 27, 2009 | 03:30 AM
ms_logging's Avatar
my boost in stock was 0.9 bar (1.2 overboost) i dont have map sensor and i am using gauge to monitor boost (i know that is not right) i have used your guide to add 1.2mm restrictor. and after that tuned wgdc to make wanted boost .and your "how to " was verry usefull for me ! thanks !
Old Jun 27, 2009 | 12:14 PM
Evo_Jay's Avatar
word. You car was boost only like 12-13 lbs then when it was stock. Stock boost on the evo 9 is 20.5 lbs, which is 1.4 bar. Most raise it to about 21-23lbs. 1.5 bar = 22lbs.
Old Jun 28, 2009 | 11:12 AM
C6C6CH3vo's Avatar
In addition it's a good idea to log AFRMAP just to see exactly what fuelmap cells your using. The value can easily be converted to AFR (X/1881.6*128). The temp and baro usually changes there too deviating from map even more. And lastly, a brief AFR dip near peak load will not hurt HP at all and in fact will provide more energy as pressure (CO combustion) than heat, theoretically allowing more turbine input
GeoMitsu
Sep 20, 2016 09:36 AM
Ian0611
Nov 14, 2010 10:30 AM
PERRIN_JOHN
24
Apr 23, 2009 11:01 AM
Spun Autosports
Evo 'For Sale' Engine Internals and Drivetrain
25
Jun 4, 2007 03:42 AM
onesicklambo
Aug 3, 2005 07:13 AM
