retardation, strangulation...
Old Jul 14, 2009 | 02:40 AM
opc's Avatar
opc
Well looking at the map, a test that goes very well (only probe to 4th) but in 3000-3200 rpm it as an unusual delay in the scooter diria as drowning or forfeited or something like that, and he does a second and then a missile ...
That can not be aver if I made a hand.
thanks and best regards.
Español:
Pues mirando el mapa, probamos uno que va muy bien ( solo lo probe hasta 4ª) pero a 3000-3200 hace como un retardo raro, en las scooter diria como que se ahoga o se retiene o algo asi, y lo hace un segundo y luego es un misil...
No se que puede ser, aver si me hechan una mano.
gracias y un saludo.
LOG:
http://rs773.rapidshare.com/files/25...1.59__by__.csv
buscar
Old Jul 15, 2009 | 02:46 AM
monsta's Avatar
Hi there,
It looks like you have too much timing from between 100-150 load and then your map suddenly changes to massive negative timing @170 load.
Knock back 10 degrees from your map from 100-150 @2500- 3000 rpm then progressively drop the timing down to @0 degrees at 270 load. That would be a good starting point.
Old Jul 15, 2009 | 05:01 AM
Appauldd's Avatar
The onset of knock caused the timing to be pulled. You would be best off to post the log details rather than the graph. And without boost and O2....you are never going to get it squared away.
In addition, you will need to post you mod list. Based on your car being an VIII, and I assume you are modded because of the higer load readings, the mod list will allow us to help you get the car dialed in.
Maybe someone who speaks spanish can assit you a bit better.
