Help with Duty Cycle Please!!!
Old Jul 19, 2009 | 06:58 PM
Stradag's Avatar
Question Help with Duty Cycle Please!!!
Ok so I logged my car with a tune that was purchased by the previous owner and the afr was way lean.....so I loaded a stock rom and now im trying to tune the afr....well I thought i was doing pretty decent until I checked duty cycle....for some reason it is showing 100%. I dont understand why. Also should i run 12.5 up until 10 psi or is it ok if I just run 11.7 from 3000 rpms to 7500? Any help would be awsome!!! thanks in advance. Oh ya my boost is at 18 psi in third and it spikes 19-19.5 in forth......also the first map tracer is my afr via zeitronix wide band.
Old Jul 20, 2009 | 06:02 PM
lan_evo_mr9's Avatar
I'm assuming you have a fuel pump, right?
Old Jul 20, 2009 | 08:58 PM
Stradag's Avatar
ya walboro 255 of course....stock injectors. I put a 100% stock map in and at higher rpm @ just about stock boost the duty cycle still shows ~100%. What woul cause this? Doesnt make sense to me.
Old Jul 21, 2009 | 08:42 AM
recompile's Avatar
Check for a boost leak off the fuel pressure regulator line (perhaps at the boost gauge, if you have one tapped there)
Old Jul 21, 2009 | 02:26 PM
Stradag's Avatar
I actually just put a new fuel pressure regulator solenoid on.....mabye theres a leak on the line. i am going to do a boostleak test tomarrow.
THANKS FOR THE REPLIES!!!
P.S. nice how to videos recompile!!!
Stradag
Apr 19, 2012 03:56 PM
Stradag
For Sale - Cars For Sale
Jul 5, 2011 06:36 PM
FL_SilverEvo8
For Sale - Miscellaneous Automotive
Apr 11, 2011 06:27 PM
Stradag
Mar 1, 2011 04:16 PM
Evo Girlie
Dec 16, 2009 08:10 AM
