Issue converting from 94170015 to 96530706
Old Aug 4, 2009 | 10:18 AM
project_skyline's Avatar
If your having issues converting to 96530706.
Post here
Old Aug 4, 2009 | 12:02 PM
Appauldd's Avatar
No wait....what was the issue????
I ask because I am running into issues too.
Old Aug 4, 2009 | 10:50 PM
I wasn't able to flash from 94170015 to 96530706. I finally got it. What issues are you having?
Old Aug 5, 2009 | 08:23 PM
Appauldd's Avatar
I've been trying to get the 96530006 up and running, but I have a ton of addresses wrong. Also, some key tuning elements I use are not supported in the 0006.
The following are missing from 96530006
Idle error tables
Knock Sum Decay Timer
EGR System Enable/Disable
The following tables have wrong addresses
MAF Adjustment
MAF Scaling
all 4 Post Primer tables
Primer Cranking Enrich
all 5 Decel Fuel Cut tables
Airflow/Hz Baro and Air Temp Compensation
Warmup Advance/Retard Activation
Air Temp Trim
Once I can get 0006 to run, I will switch over to tephras rom and give it a shot.
Any assistance would be appreciated.
Thanks.
Paul
Old Aug 5, 2009 | 08:45 PM
tephra's Avatar
Applaudd - Ca you post up the addresses for those missing tables (from 94170015)
I am found/fixed some for 96530006:
Code:
<table name="KnockSum decay timer" category="Knock Control" address="1784" type="1D" scaling="uint16"/>
<table name="MAF Scaling" category="Fuel" address="3306"  type="2D" level="3" scaling="AirFlow8">
	<table name="Load" type="Y Axis" address="67a0" elements="21" scaling="uint16"/>
</table>
<table name="Air Temperature Compensation" category="Fuel" address="333e" type="2D" level="3" flipy="true" scaling="uint8">
	<table name="Degrees" type="Y Axis" address="6af0" elements="8" scaling="Temp"/>
</table>
<table name="Idle Stability Timing Control" category="Timing" address="174e" type="2D" level="2" scaling="uint16">
	<table name="Settings" type="Static X Axis" elements="3">
		<data>Sensitivity</data>
		<data>Timing Limit</data>
		<data>Untested</data>
	</table>
</table>
<table name="Limp Home Table" category="Fuel" address="3797" type="3D" level="2" swapxy="true" scaling="uint8">
	<table name="TPS" address="69a6" type="X Axis" elements="7" scaling="Volts16"/>
	<table name="Engine Speed" address="6992" type="Y Axis" elements="5" scaling="RPM"/>
</table>
<table name="ST Fuel Max Trim" category="Fuel" address="369e" type="2D" level="2" scaling="O2 Trim">
	<table name="Engine Temp" address="69be" type="Y Axis" elements="8" scaling="Temp"/>
</table>
<table name="ST Fuel Min Trim" category="Fuel" address="36ac" type="2D" level="2" scaling="O2 Trim">
</table>
<scaling name="LT Trim Hz" units="Hz" toexpr="x*6.25" frexpr="x/6.25" format="%.2f" min="0" max="1593.75" inc="6.25" storagetype="uint8" endian="big"/>
<table name="Closed Loop - LT Trim Control" category="Fuel" address="35e5" type="2D" level="2" scaling="LT Trim Hz">
	<table name="Conditions" type="Static Y Axis" elements="4">
	<data>Low -> Mid</data>
	<data>Mid -> Low</data>
	<data>Mid -> High</data>
	<data>High -> Mid</data>
	</table>
</table>
<table name="Idle Error - Normal" category="Idle" address="435c" type="2D" level="2" scaling="ISCVSteps">
	<table name="Idle Error" address="669a" type="X Axis" elements="9" scaling="RPM"/>
</table>
<table name="Idle Error - A/C On" category="Idle" address="436c" type="2D" level="2" scaling="ISCVSteps">
</table>
- someone else can merge these into the official 96530006.xml (and set it up with the right names and stuff to match other evo's)
Old Aug 5, 2009 | 08:52 PM
Appauldd's Avatar
Tephra....sent you an Email.
Here is all of the missing tables.....These are my 94170015 tables
</table>
</table>
<table name="TPS" address="675e" type="X Axis" elements="7" scaling="Volts16"/>
<table name="Engine Speed" address="6776" type="Y Axis" elements="5" scaling="RPM"/>
</table>
<table name="Engine Temp" address="67a2" type="Y Axis" elements="8" scaling="Temp"/>
</table>
</table>
</table>
</table>
<table name="Closed Loop - LT Trim RPM" category="Fuel" address="35e9" type="2D" level="2" scaling="RPMStatLimit8">
<data>1</data>
<data>2</data>
<data>3</data>
<data>4</data>
</table>
</table>
<table name="Idle Error - Normal" category="Idle" address="434a" type="2D" level="2" scaling="ISCVSteps">
<table name="Idle Error" address="647e" type="X Axis" elements="9" scaling="RPM"/>
</table>
<table name="Idle Error - A/C On" category="Idle" address="435a" type="2D" level="2" scaling="ISCVSteps">
</table>
<table name="Set to 9 by typing 0x9 to remove load limit" address="26694" type="1D" level="2" scaling="Hex16"/>
<table name="EGR System Enable/Disable" category="Emissions EGR" address="103D" type="1D" level="2" scaling="uint8"/>
Old Aug 5, 2009 | 09:07 PM
tephra's Avatar
post updated.
let me know if there is anything else
Old Aug 5, 2009 | 09:09 PM
Appauldd's Avatar
DANG ! ! You are Fast !
Awesome work. Let me know if my 94170015 helped any.
Thanks for you help.
Old Aug 5, 2009 | 09:19 PM
tephra's Avatar
yeah most of the address were the same.. just had to fix up the axis mainly..
Old Aug 5, 2009 | 09:32 PM
Appauldd's Avatar
Found some more errors....
<table name="Warmup Advance/Retard Activation" address="41dc">
<table name="Engine Temp" address="681a"/>
</table>
<table name="Air Temp Trim" address="41b2">
<table name="Intake Air Temp" address="689e"/>
</table>
The ST Fuel trims won't show up with values in the fuel side
</table>
</table>
The Ignition trim vs... tables have the same address for engine temp and air temp
<table name="Ignition Trim vs Engine Temp" category="Timing" address="41a4" type="2D" level="2" scaling="Percent (128)">
<table name="Engine Temp" address="6aa0" type="Y Axis" elements="8" scaling="Temp"/>
</table>
<table name="Ignition Trim vs Air Temp" category="Timing" address="41b2" type="2D" level="2" scaling="Percent (128)">
<table name="Air Temp" address="6aa0" type="Y Axis" elements="8" scaling="Temp"/>
</table>
Old Aug 5, 2009 | 09:36 PM
tephra's Avatar
copy the "02 Trim" scaling (from 94170015.xml) into your 96530006.xml
That will fix the SF Fuel trims
Airtemp axis should be 6af0
Old Aug 5, 2009 | 09:39 PM
Appauldd's Avatar
Yeah I found the scaling was missing.
I believe the addresses are correct for the others, but I get some strange values in the X and Y sides. The tables themselves look to be correct.
Could I just have to past in the correct x and y values???
Old Aug 5, 2009 | 10:46 PM
Appauldd's Avatar
<table name="Airflow/Hz Baro and Air Temp Compensation" address="3351">
<table name="IAT_Comp/Baro_Bar" address="678e"/>
<table name="MAF Hz" address="67a0"/>
</table>
Are these correct ? ? ?
Old Aug 6, 2009 | 12:48 AM
I just wanted to point out that phenom has a current xml for the v7t6 that has everything current and working.
Im using it and everything seems to be how it should be and functioning properly.
Old Aug 6, 2009 | 05:59 AM
l2r99gst's Avatar
I also has most, if not all, of those tables that you asked for, but I have the most recent on my laptop. If there are any more outstanding that you need cleared up, let me know which ones, and I can paste what I have on my laptop.
