loads very high
Old Aug 6, 2009 | 07:19 PM
W2J's Avatar
W2J
loads very high
at 24psi I am getting 335 my afr's are good 11.6afr what could be causing this I am sure its not normal. I have attached one of my logs
Old Aug 6, 2009 | 07:35 PM
W2J's Avatar
W2J
I think I might have found the problem not sure though I did not change the injector size according to what I have in the map would that account for the higher loads? i.e if the size in the rom is 542 and evoscan is 513?
Old Aug 6, 2009 | 07:42 PM
tephra's Avatar
are you using loadcalc or 2byte load or 1byte load?
Old Aug 6, 2009 | 08:21 PM
W2J's Avatar
W2J
2 byte load, sir.
Old Aug 6, 2009 | 08:26 PM
spdracr's Avatar
wats ur mods. and i had a weird low load issue with some evo 9s i tune idk y lol it was spiking like 23.6 psi and not even breaking 260 load?!! on 1byte or load calc
Old Aug 6, 2009 | 08:35 PM
W2J's Avatar
W2J
^ E7 with IX turbo, hks 272's -4 -1.5, Megan 02 housing, 3" DCsports dp, hks catback, Walbro, stock injectors, spark-tech ignition non cdi, fp WG 18psi, ETS intercooler with full ETS Piping, KN Typhoon intake.
Old Aug 6, 2009 | 08:37 PM
Nissan2Evo's Avatar
I bet it's a boost leak and/or that crap KN intake.
Old Aug 6, 2009 | 08:38 PM
javip1986's Avatar
yeah. boost leak
Old Aug 6, 2009 | 08:47 PM
W2J's Avatar
W2J
thinking that too any suggestions, thinking about using compressor on the turbo intake and pressure the system should I block before the throttle body or let in go into engine?
Old Aug 6, 2009 | 09:31 PM
tephra's Avatar
boost leak.
just let the air go into the engine - it will leak though slowly.. but you should be able to "hear" the real leak first...
check your TB seals too
Old Aug 6, 2009 | 09:38 PM
Go_Lancer_Go's Avatar
boost leak.
how bad do TB seals effect the performance?
Old Aug 7, 2009 | 05:26 AM
rawkus's Avatar
Depends on how bad the seals are...
Here is a link to a boost leak detector. This helped me find two significant leaks and really comes in handy.
https://www.evolutionm.net/forums/ev...-detector.html
Dan
Old Aug 7, 2009 | 06:25 AM
rolly1818's Avatar
Registered User
boost leak bro.
do a boost leak test. ur afrs should indicate a boost leak though.
