anyone with a modded/working 88590013 map?
all i want is to be able to disable/simulate my rear O2 sensor so i can run my wideband. passing emissions would be a plus, but not necessary.
i've tried following all the threads in this forum but can't get anything to work.. example: when i add the tephra mod, i don't get "0"s and "1"s to turn things on and off. i get four-digit numbers.
i'm obviously doing something wrong. LOL
i don't mind copying every single map over (all my fuel/timing are stock 'till i get tuned)... i just need a ROM where everything works as it should. i'll paypal someone. whatever.
i just need something that WORKS :P
anyone?
anyone?
Use 88590015
There are a few good instructional posts around to help you out, but if you want to run a tephra map and are totally stock you can just load up the v5.10 rom (after copying your XML), copy your immobilizer, and go.
Lol. I'm an idiot:
1. I'm using 15. 13 is a typo. I was sleepy when I posted. Haha
2. I've looked at the ROM for v5.1. It appeared to be stock. Thank you for the confirmation!
Now. Can you tell me how valet mode works? Lol
And enabling rear O2 sensor is all there is to it? That simple?
Thanks again!
Thanks again!
mrfred
Feb 26, 2022 06:16 PM
