Need Help, rough iddle with Cosworth M2 Mivec
Old Aug 13, 2009 | 12:22 AM
evo 9 MR JDM's Avatar
Guys, need help...
Just Replaced the cam with M2 Cosworth Mivec Cam
and change the injector with PE 680
and doing EcuFlash by my self
I put Injector scaling on 570 & latency already been tuned to gain +/- 5% STFT reading in EvoScan
Now the car won't idle on 800 rpm, it needs 930-950 rpm to idle,
at 930 RPM the idle is better but still, a little bit rough
and I think the 950-ish idle is too high
anything is wrong ?
a friend told me to richen AFR to around 13.5 on idle
the problem is ,car still run 14.7 (on LC1 wideband) after i put 13,5 AFR in both High octane & Low octane Map in 500-1000 rpm, area under 10-30% Load...
so No Result...
Read on the forum that rubber turbo inlet pipe will cure rough idle, BUT after, change the turbo Stainless inlet pipe with the OEM rubber one, still rough iddle
any idea what should I do next ?
Thanks
Old Aug 13, 2009 | 12:27 AM
RoadSpike's Avatar
Originally Posted by evo 9 MR JDM
Guys, need help...
anything is wrong ?
so No Result...
Thanks
The computer will just adjust it back to 14.7 unless you disabled the o2 sensor.
I suggest adding a little bit of timing to the idle areas start with 7's and go up to like 9's but not much further or risk a p300 code.
Old Aug 13, 2009 | 09:38 AM
inco9nito99's Avatar
Make sure MIVEC timing around 0-1000rpms and up to ~50load is zero'd out. Secondly, go ahead and give it ~10degrees of timing in the same columns in TIMING values. If that doesn't help add a little fuel in the corresponding tables and play with the ISCV values (slowly bump them up).
ps. try these values
Scaling- 597
Latencies- 2.186 1.413 0.957 0.687 0.486 0.349
see if that helps bring the values closer to 0.
Old Aug 13, 2009 | 01:04 PM
biggie5252's Avatar
I had to bump up my idle to ~1000 rpm (1039? in ecuflash) or it idled rough. You'll get used to it. Don't mess with ISCV maps except the Desired initial ISCV position ac on map. Bump up the bottom two cells by ten. That will help your throttle lift off bogging/stalling when the ac is on. Do what was said about mivec and timing in the idle cells and you should be fine. At least it worked in my car.
Old Aug 13, 2009 | 09:03 PM
Appauldd's Avatar
Rough idle with cams is pretty normal. Most of us raise the idle RPM to around 1000 rpm and up the timing by a few degrees. This solves about 90% of the problem. As stated above about the ISCV tables....only the AC one needs to be messed with.
You said your STFT is +/- 5%....what about your LTFTs??? They need to be within 5% too. Some more scaling may be needed.
Old Aug 14, 2009 | 10:31 AM
I'll Try set the mivec and timing as above
Hope It works
thanks a lot Guys
Old Dec 3, 2009 | 06:04 PM
kaj's Avatar
kaj
did it work?
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
kikiturbo
Sep 29, 2014 07:25 PM
justboosted02
Aug 19, 2013 05:29 PM
Dragking2189
31
Aug 28, 2010 11:42 PM
