To those running SD on stock ECU: need logs
Old Aug 21, 2009 | 12:04 PM
JohnBradley's Avatar
I double checked all my logs of my car when I was setting it up...nothing to report for 88590015
Old Aug 21, 2009 | 12:29 PM
jrohner's Avatar
Originally Posted by rolly1818
i actually may have this problem
i will post some logs up.
on a different note, can i still use bits to lock the car in open loop?
Yeah, I disabled closed loop on mine in the periphery and it works great.
Old Aug 21, 2009 | 12:31 PM
Interesting, that is something I have done (well run in open loop anyway). I wonder if thats some of it. I noticed tip in seems to be the hardest part to tune of the whole SD thing. Idle and WOT are easy. Even cruise isnt bad, but that low vacuum/low boost area is a biotch...especially on the smaller turbos.
Old Aug 21, 2009 | 12:34 PM
l2r99gst's Avatar
I tested running in open loop as well and this issue persisted. So, I know closed loop isn't the cause.
For tip-in with SD, use the asynch_vs_tpsdelta table. My tip in, idle, curise and WOT were all just about perfect. It's just this one damn map/rpm zone where the IPW wants freak out for some reason.
Old Aug 21, 2009 | 01:08 PM
jrohner's Avatar
I didn't mean it fixed the issue we're seeing; if it did, I wouldn't know of the issue since I've been running open-loop almost the whole time I've been running an Evo 8 ECU. I meant that using periphery to disable closed-loop works great, and that getting rid of closed-loop works great.
Old Aug 21, 2009 | 01:22 PM
rolly1818's Avatar
Registered User
i have asynch vs tpsdelta tables by jscbanks setup up for the JDM IX, i am not sure if its stock but let me get home and i can post it up for you, or u can post urs and i can make a comparison.
Old Aug 22, 2009 | 09:28 PM
black2kgsr's Avatar
i experienced the same issues on the 94170015 rom with an omni 4-bar. i changed over to the 96530706 and still get the same. i have logs for the 9653 if you want them but none for the 9417. if you do need logs displaying the symptoms on the 9417 rom i can reflash i guess.
Old Aug 23, 2009 | 09:06 AM
l2r99gst's Avatar
No need to reflash. Just the fact that you had experienced it on another ROM helps out.
Old Aug 24, 2009 | 07:41 PM
rolly1818's Avatar
Registered User
firstly sorry for the late reply!
no problems here for 88570008....
NOTE: the rom i am using was made by jscbanks and it was made for the stock turbo. only made minor modifications to the rom.
if you want i can post any asynch tables u need.
Old Aug 25, 2009 | 06:05 AM
l2r99gst's Avatar
I don't need any asynch tables. I just need some logs if you can, described in the fitst post. I want to know if there is a ROM that definitely does not have this issue.
Old Aug 25, 2009 | 11:54 AM
rolly1818's Avatar
Registered User
cool, well not problems here. the other on lancerregister.com using 8857008 have reported no problems as well.
Old Aug 25, 2009 | 12:09 PM
l2r99gst's Avatar
Would you mind posting a log of what I have described in post #1? I just want to verify via logs to be sure that it is OK with that ROM.
Thanks
Old Aug 25, 2009 | 12:13 PM
rolly1818's Avatar
Registered User
Thanks
no probs, got to wait till firday when i got my "tuning" laptop, on training now.
Bewstzalot
Jul 7, 2017 01:35 PM
foxbat
Apr 26, 2017 01:58 AM
mrfred
Jan 28, 2017 09:58 PM
kaak
Jan 19, 2016 11:32 AM
