Map stock boost on ecu??and definition file help
Old Sep 1, 2009 | 04:35 PM
robc fq320mr's Avatar
Using 96260007 evo 8mr jdm don't think i have correct definition as under turbo certain tables don't look right. What should they look like?
Also what tables relate to peak boost and boost held?? I know that 159.4 is maximum and 100 is 100% duty on the wastegate but how do you tune for say 1.75 peak and 1.6 bar held??
Many thanks with any help
Old Sep 2, 2009 | 05:37 AM
anyone?? looking to map a 3 port solenoid also help please
Old Sep 2, 2009 | 02:08 PM
rolly1818's Avatar
Registered User
give me till tomorrow on this i am pretty busy now but can help.
PM me if anything.
Old Sep 2, 2009 | 03:24 PM
fostytou's Avatar
EvoM Community Team
In stock form the WGDC tables are maxed all the way down, the load tables are maxed and then slowly taper. Most tuners will just bump the boost adder value to add boost to the whole range on a stage0 flash.
You don't tune for a boost pressure, you tune for a load. If you are on the stock turbo and WG solenoid good luck holding 24psi to redline.
If you are interested in tuning toward a boost pressure see the direct boost control thread. If you are interested in holding that much boost see the 3 port thread. Combine the two for a different kind of fun.
There are, in fact, a ton of threads on this (for other roms, but they are all the same).
richardjh
Jul 28, 2017 03:49 PM
PPM
Apr 2, 2015 09:35 AM
tephra
154
Jan 5, 2014 08:18 PM
fireroasted
Aug 15, 2012 05:57 AM
mr2driver
Aug 1, 2011 06:16 AM
