Modified ROM 94170008
Old Mar 28, 2009 | 06:57 AM
PPM's Avatar
PPM
I am using a modded ROM Definition file version 94170008, since using this my boost has dropped to 10psi, no matter what I do with my mbc. This is a cut and paste of my ROM. Can anyone tell me if there is something wrong with this? The only thing I added was the perephery values.
Thanks in advance. Yes I posted something similar in Active Matrix, but I am monitoring both threads. My evo just isn't any fun at 10psi....
<rom>
<romid>
<xmlid>94170008</xmlid>
<internalidaddress>f52</internalidaddress>
<internalidhex>94170008</internalidhex>
<caseid>MN132874</caseid>
<make>Mitsubishi</make>
<market>USDM</market>
<model>Lancer</model>
<submodel>EVO8</submodel>
<transmission>Manual</transmission>
<year>2004</year>
<flashmethod>mitsukernel</flashmethod>
<memmodel>SH7052</memmodel>
</romid>
<include>evo7base</include>
<table name="High Octane Fuel Map" address="33bd">
<table name="Load" address="6440" elements="18"/>
<table name="RPM" address="6418" elements="15"/>
</table>
<table name="Low Octane Fuel Map" address="34d7">
</table>
<table name="High Octane Ignition Map 1" address="39d5">
<table name="Load" address="64a0" elements="19"/>
<table name="RPM" address="646e" elements="20"/>
</table>
<table name="Low Octane Ignition Map 1" address="3b5d">
</table>
<table name="Injector Battery Voltage Latency Compensation" address="37c0">
<table name="Battery Voltage" address="6380" elements="7"/>
</table>
<table name="Rev Limit" address="158c"/>
<table name="Stationary Rev Limit" address="2b4a"/>
<table name="Accel Enrichment" address="3864">
<table name="RPM" address="61b2" elements="15"/>
</table>
<table name="Boost Control Load Offset" address="1a70"/>
<table name="Turbo Boost Error Correction" address="4488">
<table name="Boost Error" address="6758" elements="17"/>
</table>
<table name="Boost Desired Engine Load # 1" address="44f8">
<table name="RPM" address="672e" elements="16"/>
</table>
<table name="Boost Desired Engine Load # 2" address="450e">
</table>
<table name="Boost Desired Engine Load # 3" address="4524">
</table>
<table name="Boost Desired Engine Load # 4" address="453a">
</table>
<table name="Max Wastegate Duty # 1" address="44a0">
</table>
<table name="Max Wastegate Duty # 2" address="44b6">
</table>
<table name="Max Wastegate Duty # 3" address="44cc">
</table>
<table name="Max Wastegate Duty # 4" address="44e2">
</table>
<table name="Open Loop Load # 1" address="3624">
</table>
<table name="Open Loop Load # 2" address="363a">
</table>
<table name="Open Loop Throttle Low Load" address="3656">
</table>
<table name="Open Loop Throttle High Load" address="366c">
</table>
<table name="IC Relay Timer Time" address="2498">
<table name="Condition"/>
</table>
<table name="IC Relay Timer Control Judgement" address="209e">
</table>
<table name="IC Relay Timer Air Temp" address="20a2"/>
<table name="IC Relay Timer ON Mode Switch Time" address="247e"/>
<table name="IC Relay Timer Control RPM" address="2480"/>
<table name="IC Relay Timer Control Water Temp" address="2482">
</table>
<table name="IC Relay Control Vehicle Speed" address="2486"/>
<table name="IC Relay Control EV" address="2488"/>
<table name="Desired ISCV intial step position with AC off-Neutral" address="4276">
<table name="Engine Temp" address="6630" elements="8"/>
</table>
<table name="Desired ISCV intial step position with AC off-Drive" address="4284">
</table>
<table name="Desired ISCV intial step position with AC on-Neutral" address="4292">
</table>
<table name="Desired Idle RPM-Neutral" address="425a">
</table>
<table name="Desired Idle RPM-Drive" address="4268">
</table>
<table name="High Intake Air Temp ISCV Increase" address="220e">
<table name="Condition" elements="2"/>
</table>
<table name="Boost Limit" address="3614">
<table name="RPM" address="6b7e" elements="9"/>
</table>
<table name="Desired Idle RPM with AC on" address="186c">
</table>
<table name="High Intake Air Temp Idle Speed Target" address="220a">
</table>
<table name="Wastgate Solenoid Activation RPM" address="1668">
</table>
<table name="Speed Limit" address="158e">
</table>
<table name="Injector Scaling" address="1506"/>
<table name="Min Coolant Temp for Closed Loop" address="15aa"/>
<table name="Boost Cut Delay Timer" address="159a" elements="2"/>
<table name="MAF Scaling" address="3306" scaling="AirFlow8">
<table name="Load" address="6330" elements="21"/>
</table>
<table name="MAF Smoothing Table" address="3322">
</table>
<table name="Air Temperature Compensation" address="333e" scaling="uint8">
<table name="Degrees" address="654e" elements="8"/>
</table>
<table name="Barometric Pressure Compensation" address="3351">
<table name="Atmosphere Pressure" address="631e" elements="4"/>
<table name="RPM" address="6364" elements="9"/>
</table>
<table name="Idle Stepper Look-up Table" address="4399">
<table name="Throttle Position" address="6664" elements="8"/>
<table name="RPM" address="667e" elements="27"/>
</table>
<table name="Knock Sensor Filter Map 1" address="4850">
<table name="TAR" address="6836" elements="12"/>
<table name="RPM" address="6816" elements="11"/>
</table>
<table name="Knock Sensor Filter Map 2" address="48eb">
</table>
<table name="Knock Sensor Filter Map 3" address="497b">
</table>
<table name="Knock Sensor Filter Map 4" address="4a0b">
</table>
<table name="Knock Sensor Filter Map 5" address="4a9b">
</table>
<table name="Knock Sensor Filter Map 6" address="4b2b">
</table>
<table name="Knock Sensor Filter Map 7" address="4e09">
</table>
<table name="Knock Sensor Filter Map 8" address="4e99">
</table>
<table name="Knock Sensor Filter Map 9" address="4f29">
</table>
<table name="Knock Sensor Filter Map 10" address="4fb9">
</table>
<table name="Knock Sensor Filter Map 11" address="5049">
</table>
<table name="Knock Sensor Filter Map 12" address="50d9">
</table>
<table name="Immobilizer"/>
<table name="Boost Enhancement (Anti-Lag) Start RPM" address="1680"/>
<table name="MAF Sensor Filtering" address="1508">
<table name="Load"/>
</table>
<table name="MAF Size" address="150c"/>
<table name="Boost Enhancement (Anti-lag) Stop RPM" address="1682"/>
<table name="Min Temp for Full Boost Control" address="2200"/>
<table name="Boost Control Limiting Vehicle Speed" address="2204">
</table>
<table name="ECU_PEREPHERY" category="Misc" address="faa" type="1D" level="4" scaling="Hex16"/>
</rom>
Old Mar 28, 2009 | 08:46 AM
PVD04's Avatar
If you're running a MBC, your boost problems have nothing to do with your ECU. Did you change anything physical in the engine bay before the problem started?
Old Mar 28, 2009 | 09:13 AM
PPM's Avatar
PPM
I noticed a zip tie had broken near the mbc. I replaced that. I also saw a small tear in the boot that the boost gauge hooks up to and replaced that. I didn't think the flash could have done it, cuz I went back to my stock flash and still have the same exact problem. I just cant find any holes, etc that would cause this. Would a vacuum leak do this? I have tried with the mbc all the way tight, and all the way loose and every variation in between, I always only get 10lbs... I am going to replace all of the vacuum lines i guess. I just didn't want to have to do it. I only changed boost settings in the ECU to avoid fuel cut. I still have no cell values higher than 270 though.
Could my turbo or wastegate be going bad?
Thanks for any help again.
Old Mar 28, 2009 | 11:09 AM
PPM's Avatar
PPM
Problem Fixed. Please ignore post. Thanks to all that responded.....
Old Apr 10, 2009 | 08:26 AM
Danieln's Avatar
Hi mate,
How you solve it?
I think I had the same problem with my map.
Can U please tell me what you did in order to fix this?
Thanks
Old Apr 11, 2009 | 11:22 AM
PPM's Avatar
PPM
As embarrassing as this is, it was my mbc. I also had an issue with the t connector going to it, it had a crack, I replaced that, took apart my mbc and cleaned it, tightened it all the way down and backed it out 3 full turns, this was approximately 15psi, I then adjusted to spike at 24lbs and hold 20 throughout the rpm range. Now I need to lean it out a bit cuz I am getting no knocks or less than 1 count throughout the rpm range and am losing power around 5200 - 7000, I noticed my afr is extremely conservative in that range, so I am logging some more and making adjustments. PM me if you need any help. Please keep in mind that I am a newb at this but would love to see some logs of other cars so I can get better.
Old Mar 13, 2015 | 01:12 PM
pitbulllove2003's Avatar
bye chance d you know the addresses for the ic control min rpm and ic control min load for the 94170008 rom
Old Apr 2, 2015 | 09:35 AM
Boosted Tuning
Aug 26, 2023 10:14 PM
richardjh
Jul 28, 2017 03:49 PM
tephra
151
Jun 18, 2017 03:22 PM
chetrickerman
Oct 20, 2015 07:10 AM
mrfred
Dec 21, 2014 10:13 AM
