how does my timing look to you? no knock
Old Sep 13, 2009 | 01:45 AM
hediki12's Avatar
just did some pulls and made 6 adjustments to timing im getting about 5counts at about 7200rpm and 126ish load. other than that im knock free.except for the last flash (test6) i had same knock up top and about 3 counts at peak load. now do either of the maps seem to agreesive? im running stock t25 turbo (upgrade on the way. i no its crazy small)
stock evo map
last two adjustmets
test5
test6(most recent)
Old Sep 13, 2009 | 11:15 AM
hediki12's Avatar
test 5
http://www.4shared.com/file/13236083...13_031426.html
test 6
http://www.4shared.com/file/13236083...13_033014.html
Old Sep 13, 2009 | 12:08 PM
Jack_of_Trades's Avatar
Can you post up your datalog of your final tune during a 3rd gear pull for us? you taper down to a 126 load!? What is your peak boost and what are you tapering to at redline?
Old Sep 13, 2009 | 12:25 PM
randomevo's Avatar
Just to ask. Are you tuning without a wideband?
P.S. Your like around the corner from me ;-)
Old Sep 13, 2009 | 01:15 PM
THUB's Avatar
The load looked so weird until I realized it's the stock 2G talon turbo. (t25 according to his post)
Old Sep 13, 2009 | 01:25 PM
hediki12's Avatar
yes i am v_v... im saving up for one... really?!!! pm me!
Old Sep 13, 2009 | 01:26 PM
hediki12's Avatar
umm final tune is labled as test 6 (thats what im running on the car now), and it goes with the second log. the 1st log is test 5(last rom before i uped the timing and got knock )
Old Sep 13, 2009 | 01:27 PM
hediki12's Avatar
yea. go a head laugh at my t2slow. lol.
Old Sep 13, 2009 | 02:19 PM
Even a t25 turbo should flow higher than 140 load. Thats BARELY moving air more than a N/A car. A t25 2G can put down 300whp so it should be able to flow over 200 loads. Most t25 guys run between 12-15 PSI peak, tapering to 12ish. Maybe your MAF scaling is off for the 2G MAF?? I run a 2G MAF on my Mirage with the Evo8 ECU with perfect MAF results.
Old Sep 13, 2009 | 05:19 PM
bsmart82's Avatar
A t25 will not make 300whp, a 14b maybe. How much boost are you running?
Old Sep 13, 2009 | 05:44 PM
JohnBradley's Avatar
Timing looks about what I would expect from a 2G...and oddly enough the Evo X.
Old Sep 13, 2009 | 06:57 PM
hediki12's Avatar
a t25 will NOT do 300whp. itll barely do 250 whp. and anything more than 15 psi sustained boost itll will be pushing hot air... 15psi is its efficiency limit. can you send me a pic of ur scaling btw? i wanna see how accurate i am.
Old Sep 13, 2009 | 07:02 PM
Sorry, was thinking of the power of the 14b,my bad. I know the limit of that t25 is 15psi but thats where most guys max it out to so i figured that's where you are now. What IS your boost curve? I'll get you the MAF scaling tomorrow, its on my other laptop.
Old Sep 14, 2009 | 04:56 AM
hediki12's Avatar
kool. heres mines...
Old Oct 7, 2009 | 08:50 PM
acidikjuice's Avatar
Thumbs up MAF scaling
Hey Jack of trades,
I would be interested in checking out your MAF settings that allow you to run a 2G DSM MAF with a EVO VIII ECU.
I am running an EVO ECU in my 2G DSM currently with the stock EVO MAF settings. It runs pretty good but I know I should adjust the EVO ECU settings for a 2G MAF signal.
I have changed the injector latency and injector size settings to make up for the fact that I have no idea how to scale the EVO ECU for a 2G MAF. Any tips you have making this setup run even better would be great!
Side note: I don't even have a 2G MAF on the car, I'm running a MAFT with a 3" GM MAF. But the MAFT is for a 2G DSM, so I assume that if I can dial in the EVO ECU to accept a 2G MAF signal, that it will work better with the MAFT because it is suppose to replicate a 2G MAF signal. Know what I mean ?
