openport 2.0 SD flash card logging?
Old Sep 27, 2009 | 09:01 AM
accident's Avatar
when is the logging to flash card going to happen with the openport 2.0?
I thought this was one of the features that was going to be available?
Old Sep 27, 2009 | 01:41 PM
dolphin888's Avatar
Maybe after few years, or maybe not It's not the first thread about sd card logging
Old Sep 27, 2009 | 05:42 PM
tephra's Avatar
its in beta testing now.
Old Sep 27, 2009 | 05:46 PM
accident's Avatar
sweet! let me know if you need any beta testers
Old Sep 27, 2009 | 05:52 PM
tephra's Avatar
not me dude - colby@tactrix
Old Oct 19, 2009 | 11:27 PM
SoCal Rally's Avatar
The Tactrix site now lists "logging to microSD" as a feature that is now working (http://www.tactrix.com/product_info.php?products_id=49).
- Has anyone else tried this and confirmed logging to microSD is working?
If so:
- what is the max capacity microSD supported?
- how long will logging to microSD run before a 2GB card is full?
- is it possible to log to microSD all the same parameters that EvoScan can log, or are there some limitations?
Old Oct 19, 2009 | 11:29 PM
tephra's Avatar
yes its working on my car.
i have an 8GB MicroSDHC card in there
log is about 1.5mb for 30min drive, same as evoscan really
same parameters as evoscan
MattS00's Avatar
You will want to read that.
http://forums.openecu.org/viewtopic.php?f=57&t=4319
Old Oct 20, 2009 | 01:07 AM
Tephra, thanks for the info.
MattS00, thanks for the link to the OpenPort logging thread.
Does anyone know if there is a way to log boost & wideband AFR to the OpenPort 2.0 microSD card on an Evo IX if possible e.g. by using a JDM MAP sensor, and connecting my Zeitronix wideband AFR output to a spare ECU pin or something? I am currently using a Zeitronix ZT-2 with additional boost & EGT sensors, imported into EvoScan, and would like to retain those parameters in log files I log using a microSD card, if possible.
Also:
- which bus system, e.g. CAN / K-line etc., does the Evo IX use?
- what is the max OpenPort 2.0 logging speed of the bus system that the Evo IX uses?
- what is the max number of Priority 1 level params that the OpenPort 2.0 microSD can log simultaneously?
Thanks.
Old Oct 20, 2009 | 01:51 AM
tephra's Avatar
apparently the OP20 now can log the LC1 serial thingy
Kline
fast enough
as many as you want, slower with more items thou
Old Oct 20, 2009 | 02:50 AM
dolphin888's Avatar
Question
Finally, I'm going to the store now for some microSD card.
My question would be: how can I set parameters to triger the log? Is it possible to set up RPM, TPS, etc. to initialize logging?
Old Oct 20, 2009 | 03:13 AM
tephra's Avatar
yes apparently u can.
i haven't tried
Old Oct 20, 2009 | 06:54 AM
dolphin888's Avatar
i haven't tried
How should I do that?
Old Oct 20, 2009 | 10:54 AM
It's detailed in the thread MattS00 posted above. You do it by configuring your start and stop trigger params in the logcfg.txt file in the root folder of your microSD card.
You could check out the sample code block in this post for an example: http://forums.openecu.org/viewtopic....art=105#p22122
Note: I am guessing you may have to edit the example to match the different RAM addresses & paramIDs used by your car?
It would be nice if someone who has tested this on an Evo VIII / Evo IX could post up their logcfg.txt as an example.
Note 2: make sure you update the firmware inside your OP 2.0 device as detailed in the very first post of the thread MattS00 posted to make sure you are running the latest & greatest firmware.
Old Oct 20, 2009 | 10:57 AM
SyZyGy1394's Avatar
If you are going to buy a card, buy it online. The prices they charge in retail stores is rape...
