Poor Cold Idle (Yes I searched)
Old Oct 3, 2010 | 02:02 AM
  #421
F0RSAKEN's Avatar
Originally Posted by damie45
I had this issue since day one and I'm the first owner of my car. The freaking dealer said it was normal. i can't just get in the car and drive off, I got to wait a minute or two in the summer and 5 to 10 in the winter... no quick getaway for me.
My guess is your car has a tune of some sort on it, as neither of my IX MR's had ANY sort of problem when stock/untuned.
Old Oct 3, 2010 | 07:03 AM
  #422
GG06MR's Avatar
^^^^ +1. My 1st stock IX MR didn't have that problem, and neither did the very mildly modded 2nd one I have now(when I bought it)....which was confirmed to have the OEM ECU flash settings.
Old Oct 8, 2010 | 08:13 AM
  #423
fugiwara's Avatar
is there anyway to prevent the idle spike w/out adjusting the BISS, just adjust the ROM setting?
Old Oct 8, 2010 | 09:16 AM
  #424
shadow1's Avatar
Any solution yet to the 2000 rpm warm up idle? Or is this an unavoidable consequence of the tephra 96530706 rom?
Old Oct 8, 2010 | 01:06 PM
  #425
Evoryder's Avatar
Have you tried adjusting your desired idle levels based on coolant temp. This worked the best for me. Most I get is a spike of 1400 and immediately settles to 1100 then eventually 1000
Old Oct 8, 2010 | 02:02 PM
  #426
shadow1's Avatar
No table like that defined in 96530706
Old Oct 8, 2010 | 04:55 PM
  #427
Evoryder's Avatar
Ok to b more specific. I thought u could read around it.
Desired ISCV initial step position AC off neutral
Desired ISCV initial step position AC off drive
Desired ISCV initial step position AC on neutral
Lower values in problem areas(temps) by 10% at a time till it's where u want it as far as cold starts.
https://www.evolutionm.net/forums/at...90715-iscv.png
Old Oct 12, 2010 | 04:05 AM
  #428
F0RSAKEN's Avatar
Question:
I read the first 7 pages or so, and did not get a definitive answer, but does this fix apply to 88591715? I tried most of the periphery changes, but my car ran a bit worse, and threw an engine code (couldn't pull it, evoscan will only clear DTCs for some reason).
Also, my car will not stay running when cold started, unless I blip the throttle to keep it from dying, lasts about 30 seconds. Ideas?
Old Oct 12, 2010 | 05:17 AM
  #429
Evoryder's Avatar
What are your A/F's like during the issue?
Old Oct 12, 2010 | 01:09 PM
  #430
F0RSAKEN's Avatar
16:1-19:1. Sometimes as lean as 20:1.
Old Oct 12, 2010 | 04:04 PM
  #431
Evoryder's Avatar
I had an issue with that. My fix was increasing maf comp vs coolant temp tables
Old Oct 12, 2010 | 04:15 PM
  #432
F0RSAKEN's Avatar
Will this change have an affect even on SD? Thanks for the response!
Old Oct 12, 2010 | 04:51 PM
  #433
JohnBradley's Avatar
Andrew,
Yours is the SD table and a few of the other minor tables. I just played with one today and saw exactly what is happening. Also change your periphery from 0x54D8 to 0x56D8.
aaron
Old Oct 12, 2010 | 05:00 PM
  #434
Evoryder's Avatar
My issue came about when switching to SD. This remedy fixed my issue and another members issue. I tried almost everything. Adding fuel/timing/start up ipw/ scalings etc...this table was my savior.
If JB is your tuner have him look at some alternatives. I'm almost certain this will help your issue.
Old Oct 12, 2010 | 06:27 PM
  #435
F0RSAKEN's Avatar
Originally Posted by JohnBradley
Andrew,
aaron
I'm still in the infant stages of the learning curve here... Which periphery has that address?
Also, I have the MAF comp table, but not maf comp vs. Coolant temp. What now?
