Coil Dwell on stock ECU...again
Old Aug 23, 2012 | 05:03 AM
  #91
EvocentriK's Avatar
Using the stock values or the boosted values? Has anyone tried using lower values with individual coils to see where they need to be boosted to prevent breakup as a comparison to stock coils? Any data on the coils used by Spoolinup regarding dwell?
Old Aug 23, 2012 | 05:18 AM
  #92
240Z TwinTurbo's Avatar
For two of the common denso coils the link below provides accurate dwell information. The dwell numbers are the max you should use for the two coils.
https://www.evolutionm.net/forums/10352677-post276.html
Old Aug 26, 2012 | 08:45 AM
  #93
EvocentriK's Avatar
I bumped up the dwell time on the stock coils a few notches (not as far as Aaron) as I was experiencing spark blow out at 26 psi with slightly gapped plugs. Massive difference, it holds 26psi fine now and feels much more crisp on 23psi, I'm impressed.
Old Nov 21, 2012 | 06:21 AM
  #94
RJSP's Avatar
Are you guys bumping the 2800 rpm Dwell-Time reduction RPM to a higher value or just adjusting the Dwell-Time and Dwell-Time reduction factor tables?
What would be the address to log dwell-time with evoscan in an Evo 5?
Old Dec 26, 2012 | 07:43 AM
  #95
EvocentriK's Avatar
I just bumped dell time initially, but today I also dropped the reduction factor 1 notch also. dwell reduction rpm I have left stock at 2800 rpm
Old Dec 28, 2012 | 02:42 PM
  #96
dom11's Avatar
Originally Posted by merlin.oz
Here are some scripts to add to your xmls.
I have included the second correction, though I dont understand how it works at present.
I am confident on the scaling though, weird as they may be.
<!-- IGNITION COIL DWELL-TIME TABLES -->
<!-- SCALINGS -->
<scaling name="ChargeTime" units="mS" toexpr="x*0.064" frexpr="x/0.064" format="%.2f" min="0" max="16.32" inc="0.064" storagetype="uint8" endian="big"/>
<scaling name="BatteryVoltage" units="Volts" toexpr="x*75/1024" frexpr="x*1024/75" format="%.2f" min="0" max="18.75" inc="0.5" storagetype="uint16" endian="big"/>
<scaling name="CF256" units="Correction Factor" toexpr="x/256" frexpr="x*256" format="%.3f" min="0" max="2" inc="0.0039" storagetype="uint8" endian="big"/>
<scaling name="Percent128" units="%" toexpr="x/1.28" frexpr="x*1.28" format="%.0f" min="0" max="100" inc="1" storagetype="uint8" endian="big"/>
<scaling name="BattVoltDwell%" units="%" toexpr="x*75/1024" frexpr="x*1024/75" format="%.2f" min="0" max="18.75" inc="0.5" storagetype="uint16" endian="big"/>
<scaling name="RPMLimit" units="RPM" toexpr="7500000/x" frexpr="7500000/x" format="%.0f" min="0" max="9000" inc="60" storagetype="uint16" endian="big"/>
Evo6
25570000
<table name="Ignition Coil, Dwell-Time" address="1229e" category="Timing" type="2D" scaling="ChargeTime">
<table name="Battery" address="2c7c8" type="Y Axis" elements="9" scaling="BatteryVoltage"/>
</table>
<table name="Ignition Coil, Dwell-Time Reduction RPM" category="Timing" address="10A46" type="1D" scaling="RPMLimit"/>
<table name="Ignition Coil, Dwell-Time Reduction Factor" address="122ac" category="Timing" type="2D" scaling="CF256">
</table>
<table name="Ignition Coil, Dwell-Time Correction 2" address="122ba" category="Timing" type="2D" scaling="Percent128">
<table name="Battery" address="2c7c8" type="Y Axis" elements="9" scaling="BattVoltDwell%"/>
</table>
Evo7
90550001
98640014
<table name="Ignition Coil Dwell Time" address="404e" category="Timing" type="2D" scaling="ChargeTime">
<table name="Battery" address="4f34" type="Y Axis" elements="9" scaling="BatteryVoltage"/>
</table>
<table name="Ignition Coil, Dwell-Time Reduction RPM" category="Timing" address="1746" type="1D" scaling="RPMLimit"/>
<table name="Ignition Coil, Dwell-Time Reduction Factor" address="405e" category="Timing" type="2D" scaling="CF256">
</table>
<table name="Ignition Coil, Dwell-Time Correction 2" address="406e" category="Timing" type="2D" scaling="Percent128">
<table name="Battery" address="4f34" type="Y Axis" elements="9" scaling="BattVoltDwell%"/>
</table>
Evo8
96260009
96260012
<table name="Ignition Coil, Dwell-Time" address="3e4e" category="Timing" type="2D" scaling="ChargeTime">
<table name="Battery" address="5aac" type="Y Axis" elements="9" scaling="BatteryVoltage"/>
</table>
<table name="Ignition Coil, Dwell-Time Reduction Factor" address="3e5e" category="Timing" type="2D" scaling="CF256">
</table>
<table name="Ignition Coil, Dwell-Time Correction 2" category="Ignition Coil" address="3e6e" type="2D" scaling="Percent128">
<table name="Battery" address="5aac" type="X Axis" elements="9" scaling="BattVoltDwell%"/>
</table>
Evo8
94170008
<table name="Ignition Coil, Dwell-Time" address="41ea" category="Ignition Coil" type="2D" scaling="ChargeTime">
<table name="Battery" address="6398" type="Y Axis" elements="9" scaling="BatteryVoltage"/>
</table>
<table name="Ignition Coil, Dwell-Time Reduction Factor" address="41fa" category="Ignition Coil" type="2D" scaling="CF256">
</table>
<table name="Ignition Coil, Dwell-Time Correction 2" category="Ignition Coil" address="420a" type="2D" scaling="Percent128">
<table name="Battery" address="6398" type="X Axis" elements="9" scaling="BattVoltDwell%"/>
</table>
Evo8
94170015
<table name="Ignition Coil, Dwell-Time" category="Ignition Coil" address="41ea" type="2D" scaling="ChargeTime">
<table name="Battery" address="69bc" type="X Axis" elements="9" scaling="BatteryVoltage"/>
</table>
<table name="Ignition Coil - Dwell-Time Reduction RPM" category="Timing" address="1746" type="1D" scaling="RPMLimit"/>
<table name="Ignition Coil, Dwell-Time Reduction Factor" category="Ignition Coil" address="41fa" type="2D" scaling="CF256">
</table>
<table name="Battery" address="69bc" type="X Axis" elements="9" scaling="BattVoltDwell%"/>
</table>
Evo8
96530006
<table name="Battery" address="6808" type="Y Axis" elements="9" scaling="BatteryVoltage"/>
</table>
</table>
<table name="Battery" address="6808" type="X Axis" elements="9" scaling="BattVoltDwell%"/>
</table>
Evo9
88580013
88580014
<table name="Ignition Coil, Dwell-Time" category="Timing" address="3cc6" type="2D" scaling="ChargeTime">
<table name="Battery" address="6f14" type="Y Axis" elements="9" scaling="BatteryVoltage"/>
</table>
<table name="Ignition Coil, Dwell-Time Reduction RPM" category="Timing" address="1346" type="1D" scaling="RPMLimit"/>
<table name="Ignition Coil, Dwell-Time Reduction Factor" category="Timing" address="3cd6" type="2D" scaling="CF256">
</table>
<table name="Ignition Coil, Dwell Time Correction 2" category="Timing" address="3ce6" type="2D" scaling="Percent128">
<table name="Battery" address="6f14" type="Y Axis" elements="9" scaling="BattVoltDwell%"/>
</table>
Evo9
88590015
<table name="Battery" address="6e0c" type="Y Axis" elements="9" scaling="BatteryVoltage"/>
</table>
</table>
<table name="Ignition Coil, Dwell-Time Correction 2" category="Timing" address="3ce6" type="2D" scaling="Percent128">
<table name="Battery" address="6e0c" type="Y Axis" elements="9" scaling="BattVoltDwell%"/>
</table>
Evo9
98280002
<table name="Ignition Coil, Dwell-Time" category="Timing" address="35FC" type="2D" scaling="ChargeTime">
<table name="Battery" address="5F00" type="Y Axis" elements="9" scaling="BatteryVoltage"/>
</table>
<table name="Ignition Coil, Dwell-Time Reduction Factor" category="Timing" address="360C" type="2D" scaling="CF256">
</table>
<table name="Ignition Coil, Dwell-Time Correction 2" category="Timing" address="361C" type="2D" scaling="Percent128">
<table name="Battery" address="5F00" type="Y Axis" elements="9" scaling="BattVoltDwell%"/>
</table>
Can you help with 88840017? Please!
Old Dec 28, 2012 | 11:51 PM
  #97
evodomUA's Avatar
Do we have any chance to open injector phasing tables on stock ECU?
Old Dec 30, 2012 | 03:51 PM
  #98
3gturbo's Avatar
I just added a cop setuo to my 2g what a difference it made changing these values.
Old Dec 30, 2012 | 05:04 PM
  #99
domyz's Avatar
What is your new dwell time settings after the COP?
Which coil you have in your COP setup?
Beware not to overheat them from too long dwell time...
Old Dec 30, 2012 | 05:23 PM
  #100
merlin.oz's Avatar
There are no injector phasing tables in the Mitsubishi ROMs.
I have found the best way to combat plug blow-out when using the stock coils is to reduce the Dwell Time reduction factor. This keeps the same dwell time as stock at idle and rpm below 2800, so the coils dont overheat.
Reducing the factor makes the dwell time higher at high rpm. If the factor is set to zero, there is no reduction in dwell time, so it gets whatever is in the dwell time table.
The Spoolinup coils do seem to like a reduction in dwell time factor in my experience.
Old Dec 30, 2012 | 06:44 PM
  #101
domyz's Avatar
Great, thanks for the clarification merlin. I just saw your updated XML and tables, thanks for the work.
Old Dec 30, 2012 | 07:43 PM
  #102
3gturbo's Avatar
i just used the 2g dsm settings. My cop setup uses the intrepid coils. I also zeroed out the 2nd table like the dsm ecu.
Old Jan 17, 2013 | 05:04 PM
  #103
utripin's Avatar
Tweaking the Dwell-Time Reduction factor table and logging the result will certainly get you there with minimal fuss, though the logged values do fritz arround a bit.
To help reduce the jittering (I believe caused by battery voltage changing) set the 12.89V, 14.06V and 15.23V settings (both tables) to the same value while experimenting.
The third table to me is looking like a maximum dwell duty cycle table.
I am confident the scaling is Percent128 though I dont know exactly what its doing.
Additionally, the 1D parameter befoer the rpm threshold is also involved somehow.
It is a time thingy equal to 60uS but unknown application/math.
Merlin, what are you suggesting to set the 12.89V, 14.06V and 15.23V settings too? Both tables??
Old Jan 17, 2013 | 05:37 PM
  #104
domyz's Avatar
<!-- SCALINGS -->
Evo6
25570000
</table>
</table>
</table>
Evo7
90550001
98640014
</table>
</table>
</table>
Evo8
96260009
96260012
</table>
</table>
</table>
Evo8
94170008
</table>
</table>
</table>
Evo8
94170015
</table>
</table>
</table>
Evo8
96530006
</table>
</table>
</table>
Evo9
88580013
88580014
</table>
</table>
</table>
Evo9
88590015
</table>
</table>
</table>
Evo9
98280002
</table>
</table>
</table>
JB or a mod should update the first post with the above XML entries.
Old Jan 17, 2013 | 05:49 PM
  #105
JohnBradley's Avatar
updated
