Advanced fuel control options
Old Dec 9, 2009 | 02:24 PM
  #106
Appauldd's Avatar
What load / Hz would we seek as a happy mid point between high and mid ? ? ?
Old Dec 9, 2009 | 10:25 PM
  #107
03whitegsr's Avatar
Originally Posted by fostytou
You people, I suggested dropping it to ~800hz months ago!
We also had no idea it affected WOT fueling...
Or that it was fixed at 128.
The fact that it's fixed at 128 and used at WOT kind of ruins my intial plan to make low = idle, mid = light throttle, high = cruise.
It seems like my car usually cruises around 250-300 Hz, but I'd have to grab some more logs. I don't recall seeing over 500 in closed loop though. Could probably back calculate it though from the highest load and RPM that will stay in closed loop.
Old Dec 11, 2009 | 09:49 AM
  #108
tnt1106's Avatar
I still can't make any changes to the Sync Load Accel or Decel IPW values, it just 0's them out. Any ideas? v1.42 ecuflash.
Old Dec 11, 2009 | 12:09 PM
  #109
nonschlont's Avatar
I just noticed the same issue last night. also 1.42
Dumb question for clarity: the 3 Decel IPW tables are the equivelent of the decel fuel cut tables (4 the 88580015 rom) , correct? Looking to cure a lil throttle hang...
Old Dec 11, 2009 | 03:26 PM
  #110
Slo_crx1's Avatar
Hey just a quick note on the table posted for 96530006 for the Async accel multiplier vs TPS Delta...if you end up adding the percent sign in with the numbers between the <data> bulletins, it will end up displaying all your values in a straight line vertically. Also, the Mult128 scaling does not work for me at all, it changes the values of the tables as it should, but when I go to make changes (any change, plus or minus) to the values, they automatically drop to 0.
I've been playing with it for the last 3 hours getting pretty pissed off too, figured I had something major screwed up in my xml for a while lol.
Old Dec 14, 2009 | 07:27 AM
  #111
tnt1106's Avatar
bump to above three of us having same issue? any ideas?
Old Dec 14, 2009 | 11:06 AM
  #112
D-VO's Avatar
I've seen this happen with a lot of the scalings; its sort of like they can only be set one way (such as MAF HZ). I think the only way to modify it would be to change the formula. I hope that helps.
Old Dec 14, 2009 | 02:33 PM
  #113
03whitegsr's Avatar
With regards to scaling equations, people need to realize the increment value matters.
You need to have the increment value set to something that will induce a correct response. If you have a table that varies from 0-1 in 0.01 increments and then set the increment setting to 1, you can only set the table to 1 or 0, nothing inbetween unless you type it in.
Any time I add a new scaling, I check the resolution and set the increment size to an appropriate value. Typically just to what one raw bit count would change the output by. Unless it's a 16 bit scaling, then doing that is usually way too fine and makes the +/- key worthless.
Old Dec 15, 2009 | 05:41 AM
  #114
shadow1's Avatar
Originally Posted by 03whitegsr
Is this the correct table for 9653XXX6
Code:
    <table name="Closed Loop - LT Trim Control" address="35e5" category="Closed Loop Control" type="2D" level="2" scaling="AirFlow Hz">
        <table name="Condition" type="Static Y Axis" elements="4">
            <data>Low -> Mid</data>
            <data>Mid -> Low</data>
            <data>Mid -> High</data>
            <data>High -> Mid</data>
        </table>
    </table>
The address is not correct. Anyone have this address for 96530006?
Old Dec 15, 2009 | 06:17 AM
  #115
logic's Avatar
shadow1: just checking my disassembly quickly, it shows 35e5 as the correct address for 9653 ROMs. Why do you suspect it's incorrect?
Old Dec 15, 2009 | 06:56 AM
  #116
03whitegsr's Avatar
Sure seems right to me.
If it doesn't display right, check the scaling. My "Airflow Hz" may not match what you have for scaling. Here is what I have.
<scaling name="AirFlow Hz" units="Hz" toexpr="x*6.25" frexpr="x/6.25" format="%.0f" min="0" max="1593.75" inc="6.25" storagetype="uint8" endian="big"/>
These are not the stock values for the low end.
Old Dec 15, 2009 | 08:55 AM
  #117
tnt1106's Avatar
right, however i can not enter in any values, for example: if the value is 1.41 , and i try to renter 1.41. it goes to 0
Old Dec 15, 2009 | 09:59 AM
  #118
shadow1's Avatar
My tables shows no numbers at all.
edit - nevermind - there was a typo in the formula. It works now. Thanks guys.
Old Dec 16, 2009 | 04:23 PM
  #119
phenem's Avatar
I am trying to edit the Async Accel Multiplier vs TPS Delta on my 96530006 ROM, here is what I have:
When I try and change any of the values it just goes to 0, what am I doing wrong, I know it's something stupid....
Old Dec 16, 2009 | 04:30 PM
  #120
RoadSpike's Avatar
EDIT!
Noticed there were TWO of these scalings now both are included
Change this scaling
<scaling name="Mult128-16" units="Multiplication Factor" toexpr="x/128" frexpr="x/128" format="%.2f" min="0" max="5" inc="0.02" storagetype="uint16" endian="big"/>
<scaling name="Mult128" units="Factor" toexpr="x/128" frexpr="x/128" format="%.2f" min="0" max="5" inc="0.02" storagetype="uint8" endian="big"/>
To this Scaling (just of memory i may have reversed the two )
<scaling name="Mult128-16" units="Multiplication Factor" toexpr="x/128" frexpr="x*128" format="%.2f" min="0" max="5" inc="0.02" storagetype="uint16" endian="big"/>
<scaling name="Mult128" units="Factor" toexpr="x/128" frexpr="x*128" format="%.2f" min="0" max="5" inc="0.02" storagetype="uint8" endian="big"/>
