Advanced fuel control options
Old Nov 14, 2013 | 04:32 PM
  #256
domyz's Avatar
Yes it's during spoolup. I've not mess with Lean spool which is disabled from since I had the car. I don't really want to activate it because it's known to be inconsistent.
I'm aware of the exhaust gaz delay, but as soon as I get a little leaner on spoolup I get knock so I think AFR reading may be quite precise.
Old Nov 26, 2013 | 02:03 PM
  #257
burgers22's Avatar
I have found lean spool to be quite consistent, the longer are at WOT the richer the fueling, including when going through the gears.
Old Nov 26, 2013 | 02:09 PM
  #258
domyz's Avatar
Nice, should give it a try
Old Apr 25, 2018 | 05:37 AM
  #259
jmedina23's Avatar
Does anyone has this issue before? I have been looking in the search button but apparently this hasn't been brought up before. It is just about the scaling of the ASYNC Tables see attached. I just copy and paste what mrfred has in the thread post related to the 8859 XML.
P.S. This is for a 8859 XML EVO 9 USDM
Old Apr 26, 2018 | 04:33 AM
  #260
jmedina23's Avatar
Anything help......If there is somebody with a 8859 XML fully functional and with full capabilities (tables, scaling, etc) let me know so I can test it in my car. I'm getting some issues taking off ( The car lean out entirely below 1K) and I have done everything that people with the same problem have done without any luck.
Old Apr 26, 2018 | 06:37 AM
  #261
mines5's Avatar
PM me your email id.
Old Apr 26, 2018 | 06:44 AM
  #262
jmedina23's Avatar
PM Sent mines5. Thanks for reach me out.
Old Nov 18, 2018 | 06:51 PM
  #263
btack's Avatar
xml for low pulse width adder evo 9?
Wanted to see if anyone had the data for the "Low pulse width adder" table for a evo 9 that I can add to my .xml file? Can't seem to find it for some reason Rom ID# 8859xxxx
Old Nov 19, 2018 | 04:40 AM
  #264
jmedina23's Avatar
Here we go.
<scaling name="InjLinearizationPWScale" units="PW Adder (ms)" toexpr="x*0.004" frexpr="x/0.004" format="%.3f" min="0" max="0.5" inc="0.004" storagetype="uint8" endian="big"/>
<table name="Injector Flow Linearization PW Adder" category="Fuel" address="31db" type="2D" level="2" scaling="InjLinearizationPWScale">
<table name="Requested FPW (ms)" type="Static Y Axis" elements="66">
<data>0.016</data>
<data>0.048</data>
<data>0.080</data>
<data>0.112</data>
<data>0.144</data>
<data>0.176</data>
<data>0.208</data>
<data>0.240</data>
<data>0.272</data>
<data>0.304</data>
<data>0.336</data>
<data>0.368</data>
<data>0.400</data>
<data>0.432</data>
<data>0.464</data>
<data>0.496</data>
<data>0.528</data>
<data>0.560</data>
<data>0.592</data>
<data>0.624</data>
<data>0.656</data>
<data>0.688</data>
<data>0.720</data>
<data>0.752</data>
<data>0.784</data>
<data>0.816</data>
<data>0.848</data>
<data>0.880</data>
<data>0.912</data>
<data>0.944</data>
<data>0.976</data>
<data>1.008</data>
<data>1.040</data>
<data>1.072</data>
<data>1.104</data>
<data>1.136</data>
<data>1.168</data>
<data>1.200</data>
<data>1.232</data>
<data>1.264</data>
<data>1.296</data>
<data>1.328</data>
<data>1.360</data>
<data>1.392</data>
<data>1.424</data>
<data>1.456</data>
<data>1.488</data>
<data>1.520</data>
<data>1.552</data>
<data>1.584</data>
<data>1.616</data>
<data>1.648</data>
<data>1.680</data>
<data>1.712</data>
<data>1.744</data>
<data>1.776</data>
<data>1.808</data>
<data>1.840</data>
<data>1.872</data>
<data>1.904</data>
<data>1.936</data>
<data>1.968</data>
<data>2.000</data>
<data>2.032</data>
<data>2.064</data>
<data>2.096</data>
</table>
</table>
Old Nov 30, 2018 | 02:08 AM
  #265
btack's Avatar
Thank you sir!
tephra
70
Jul 11, 2024 12:59 AM
itzwolf
Mar 15, 2022 06:18 AM
tephra
Nov 22, 2019 10:05 PM
tephra
Jan 24, 2013 12:24 AM
Piper747
Oct 9, 2010 01:14 PM
