Advanced fuel control options
Old Jun 10, 2011 | 06:29 AM
  #226
acidtonic's Avatar
Did anyone ever post warmup enrichment tables for the Evo 9 rom? 88590015 V7.
I also have this lean condition on cold start below 2000rpm where it dips into 15.5-16.5, misses once and bounces back to 14.7.
I believe that table discussed in post #133 is not in my defs and probably what I need to adjust.
Old Jun 11, 2011 | 08:57 AM
  #227
mrfred's Avatar
Its the "maf comp vs coolant temp" tables in my first post.
Old Jun 11, 2011 | 11:11 AM
  #228
acidtonic's Avatar
That's the table? I thought it was a 3d table I was after. My bad.
Old Aug 14, 2011 | 06:35 PM
  #229
Jonesey I7's Avatar
Has anyone worked on these for the Evo 8 roms?!??! Or am I just an idiot and not looking in the right places?
Old Aug 14, 2011 | 08:54 PM
  #230
mrfred's Avatar
The table defs have been ported over to some of the Evo 8 ROMs a few pages into this thread.
Old Aug 25, 2011 | 05:59 AM
  #231
simple_lancer's Avatar
Has anyone found any of these tables for 96260709 or 96260009?
Old Sep 2, 2011 | 06:17 AM
  #232
92LaserRs's Avatar
Was wondering if since the Sync Load Idle tables dont exist in 9653 if that might be a contributor to allot of the idle/stalling issues?
Old Sep 11, 2011 | 09:19 PM
  #233
dude's Avatar
Anybody with 9417 addresses for these tables?
Bueller? Bueller?
Old Sep 24, 2011 | 07:31 AM
  #234
justastockevo's Avatar
8858xxxx tables found so far, use at your own risk, please confirm if they work for you.
Code:
<table name="Cranking Primer Initial Pulse" category="Fuel" address="5240" type="2D" level="2" scaling="TimeInjCranking">
	<table name="Coolant Temperature" address="7100" type="Y Axis" elements="9" scaling="Temp"/>
</table>
<table name="Cranking Primer Initial Pulse (Unused)" category="Fuel" address="32fc" type="2D" level="2" scaling="TimeInjCranking">
</table>
<scaling name="TimeTCOMPCrankingHack" units="Approximate ms" toexpr="x*0.9" frexpr="x/0.9" format="%.1f" min="0" max="500" inc="1" storagetype="uint8" endian="big"/>
<table name="Initial Cranking IPW vs Coolant Temp" category="Fuel" address="5F7A" type="2D" level="2" scaling="TimeTCOMPCrankingHack">
<table name="Engine Temp" address="711C" type="Y Axis" elements="11" scaling="Temp"/>
</table>
<scaling name="Percent (128)" units="Percent (%)" toexpr="x/1.28" frexpr="x*1.28" format="%.0f" min="0" max="100" inc="1" storagetype="uint8" endian="big"/>
<table name="Cranking IPW Compensation vs Time" category="Fuel" type="2D" level="2" scaling="Percent (128)" address="323E">
  <table name="Time Since Engaging Starter (sec)" type="Static Y Axis" elements="20">
    <data>0.000</data>
    <data>0.022</data>
    <data>0.044</data>
    <data>0.066</data>
    <data>0.088</data>
    <data>0.110</data>
    <data>0.132</data>
    <data>0.154</data>
    <data>0.176</data>
    <data>0.198</data>
    <data>0.220</data>
    <data>0.242</data>
    <data>0.264</data>
    <data>0.286</data>
    <data>0.308</data>
    <data>0.330</data>
    <data>0.352</data>
    <data>0.374</data>
    <data>0.396</data>
    <data>0.418</data>
  </table>
</table>
<scaling name="Percent64(8-bit)" units="%" toexpr="100*x/64" frexpr="64*x/100" format="%.0f" min="0" max="400" inc="1" storagetype="uint8" endian="big"/>
<table name="BFPW Startup Comp vs Coolant Temp #1" category="Fuel" address="3146" type="2D" level="2" scaling="Percent64(8-bit)">
  <table name="Coolant Temp" address="7100" type="Y Axis" elements="9" scaling="Temp"/>
</table>
<table name="BFPW Startup Comp vs Coolant Temp #2" category="Fuel" address="3156" type="2D" level="2" scaling="Percent64(8-bit)">
</table>
<table name="MAF Comp vs Coolant Temp #1" category="Fuel" address="3136" type="2D" level="1" scaling="uint8">
</table>
<table name="MAF Comp vs Coolant Temp #2" category="Fuel" address="3126" type="2D" level="1" scaling="uint8">
</table>
<scaling name="LT Trim Hz" units="Hz" toexpr="x*6.29" frexpr="x/6.29" format="%.0f" min="0" max="1610" inc="6.29" storagetype="uint8" endian="big"/>
<table name="Closed Loop - LT Trim Control Ranges" category="Fuel" address="3021" type="2D" level="1" scaling="LT Trim Hz">
  <table name="Conditions" type="Static Y Axis" elements="4">
  <data>Low -> Mid</data>
  <data>Mid -> Low</data>
  <data>Mid -> High</data>
  <data>High -> Mid</data>
  </table>
</table>
<scaling name="AirDensComp" units="Air Density Correction" toexpr="x/129" frexpr="x/129" format="%.3f" min="0" max="2" inc="0.01" storagetype="uint8" endian="big"/>
<table name="Air Density Compensation for Load And IPW" category="Misc" type="2D" level="2" scaling="AirDensComp" address="30fe">
  <table name="MAF Air Temp" type="Y Axis" elements="8" scaling="Temp" address="7252"/>
</table>
Old Feb 11, 2012 | 09:31 AM
  #235
CDrinkH2O's Avatar
Originally Posted by logic
For 96530006, the addresses to add to the MUT table (from mrfred's second post) appear to be; note that these are two-byte values, so each value is two MUT table entries:
Code:
60-61 Sync Base FPW			(to be determined)
62-63 Sync Load Accel FPW		ffff8a72 & ffff8a73
64-65 Sync Load Decel FPW Subtraction	ffff8a74 & ffff8a75
66-67 Sync Load Change Idle FPW		(doesn't exist)
68-69 Total Sync FPW			ffff8a6a & ffff8a6b
6A-6B Async Accel FPW			ffff8b38 & ffff8b39
6C-6D Cranking FPW			ffff8afa & ffff8afb
6E-6F Primer Pulse			ffff8ba8 & ffff8ba9
For "Sync Base FPW", we'll need to get the patch portion of mrfred's post ported over first, but I thought it might be helpful to get this into people's hands sooner rather than later.
(It looks like FFFF8A68 or 8A64 should be workable for Sync Base FPW, in case Eric or someone else gets a chance to look at the patch before I do. And on that note, time for lunch. )
I'm chasing a lean tip in issue and have setup FPW logging for Tephra V7 rom 96530706 using the addresses suggested in logic's post above.
Two questions:
1. Can anyone confirm the MUT table addresses for 96530706? I'm logging lots of zeros for Async Accel FPW using ffff8b38 & ffff8b39 from logic's post above.
2. Did anyone port mrfred's patch to calculate and store Sync Base FPW over to 96530006? I've been searching for this one so long it's becoming a bit of a holy grail
Old Feb 11, 2012 | 10:24 AM
  #236
mrfred's Avatar
Two questions:
There really isn't much contribution from async accel. My experience is that 95% of the fuelling is handled by Sync Base FPW. Are you running in SD mode or MAF mode?
Old Feb 11, 2012 | 10:53 AM
  #237
CDrinkH2O's Avatar
Thanks for the rapid response mrfred. I'm running MAF mode. Is there a ported version of your patch that I can use to log Sync Base FPW on 96530706?
Old Feb 12, 2012 | 09:39 PM
  #238
CDrinkH2O's Avatar
I've figured out that MUT 29 (0xFFFF99AA) & 2A (0xFFFF99AB) can be used to log 2-Byte FPW for 96530706. Altough this is not the Base synch FPW mentioned in this thread, it should give me some insight into what is happening during the lean tip-in at low revs (500-2500 rpm). My strategy to enrich will be to increase Async Accel vs. RPM which is currently all zeros (stock setting) between 1500 - 2500 RPM. Does this sound reasonable to the more knowledgable of you?
Old Feb 12, 2012 | 11:44 PM
  #239
mrfred's Avatar
I've not seen a patch. Have you done a boost leak check recently? Is the lean tip-in issue during off-boost driving or or when going WOT?
Old Feb 13, 2012 | 01:21 AM
  #240
CDrinkH2O's Avatar
During off boost cruising, picking up a closed throttle, at between 1000-3000 rpm, I see a 2-3 point spike in AFRs (ZT-3 LCD isplay) for a split second before they dive down to where they should be. This is particularly troublesome when the motor is cold (on E85) because it stumbles and judders and can be a liability if you are crossing an intersection. MAF scaling and compensation are stock. MAF Comp vs Coolant temp is already raised slightly at coolant temps of 93 deg F and under to help with E85's low volatility during startup. Even so, the lean spike is still there.
WOT is no problem - I leak tested a couple of weeks ago and held 30 psi with normal leakdown rates.
I will log Load, RPM, TPS, JDMMAP, WBO2 and 2-Byte IPW tomorrow throughout the warmup cycle to see what is going on with IPW on tip-in. Will post back what I find.
