2byte load logging issue..help
Old Oct 26, 2009 | 05:37 PM
NOMIEZVR4's Avatar
Hey guys, I recently started to learn how to tune my evo8.
To start off I have ECUFlash v1.42 and Evoscan v2.6.
The issue I'm having is that I am trying to log 2byte load but everytime I do, it comes out in 4 digits (2821.875) and its constantly the same number. On evoscan I have "load MUT 2byte mod" checked off.
I have also attached what i have in my ECUflash rommetadata file.
What am i doing wrong??
THANKS IN ADVANCE
<rom>
<romid>
<xmlid>96940011</xmlid>
<internalidaddress>f52</internalidaddress>
<internalidhex>96940011</internalidhex>
<make>Mitsubishi</make>
<market>USDM</market>
<model>Lancer</model>
<submodel>EVO8</submodel>
<transmission>Manual</transmission>
<year>2005</year>
<flashmethod>mitsukernel</flashmethod>
<memmodel>SH7052</memmodel>
</romid>
<include>evo7base</include>
<table name="High Octane Fuel Map" address="2abd">
<table name="Load" address="5c88" elements="18"/>
<table name="RPM" address="5c60" elements="15"/>
</table>
<table name="Low Octane Fuel Map" address="2bd7">
</table>
<table name="High Octane Ignition Map 1" address="30ad">
<table name="Load" address="5ce8" elements="19"/>
<table name="RPM" address="5cb6" elements="20"/>
</table>
<table name="Low Octane Ignition Map 1" address="3235">
</table>
<table name="Injector Battery Voltage Latency Compensation" address="2e98">
<table name="Battery Voltage" address="5bc8" elements="7"/>
</table>
<table name="Rev Limit" address="118c"/>
<table name="Stationary Rev Limit" address="2750"/>
<table name="Accel Enrichment" address="2f3c">
<table name="RPM" elements="15"/>
</table>
<table name="Boost Control Load Offset" address="1670"/>
<table name="Turbo Boost Error Correction" address="3b24">
<table name="Boost Error" address="5fd6" elements="17"/>
</table>
<table name="Boost Desired Engine Load # 1" address="3b84">
<table name="RPM" address="5fac" elements="16"/>
</table>
<table name="Boost Desired Engine Load # 2" address="3b9a">
</table>
<table name="Boost Desired Engine Load # 3" address="3bb6">
</table>
<table name="Max Wastegate Duty # 1" address="3b3c">
</table>
<table name="Max Wastegate Duty # 2" address="3b52">
</table>
<table name="Max Wastegate Duty # 3" address="3b6e">
</table>
<table name="Open Loop Load # 1" address="2d24">
<table name="RPM" address="596c" elements="16"/>
</table>
<table name="Open Loop Load # 2" address="2d3a">
</table>
<table name="Open Loop Throttle Low Load" address="2d56">
</table>
<table name="Open Loop Throttle High Load" address="2d6c">
</table>
<table name="IC Relay Timer Time" address="2090">
<table name="Condition"/>
</table>
<table name="IC Relay Timer Control Judgement" address="209e">
</table>
<table name="IC Relay Timer Air Temp" address="20a2"/>
<table name="IC Relay Timer ON Mode Switch Time" address="2084"/>
<table name="IC Relay Timer Control RPM" address="2086"/>
<table name="IC Relay Timer Control Water Temp" address="2088">
</table>
<table name="IC Relay Control Vehicle Speed" address="208c"/>
<table name="IC Relay Control EV" address="2082"/>
<table name="Desired ISCV intial step position with AC off-Neutral" address="393c">
<table name="Engine Temp" address="5e5e" elements="8"/>
</table>
<table name="Desired ISCV intial step position with AC off-Drive" address="3950">
</table>
<table name="Desired ISCV intial step position with AC on-Neutral" address="3964">
<table name="Engine Temp" address="5e78" elements="8"/>
</table>
<table name="Desired Idle RPM-Neutral" address="3920">
</table>
<table name="Desired Idle RPM-Drive" address="392e">
</table>
<table name="High Intake Air Temp ISCV Increase" address="1e14">
<table name="Condition" elements="2"/>
</table>
<table name="Boost Limit" address="2d14">
<table name="RPM" address="640e" elements="9"/>
</table>
<table name="Boost Enhancement (Anti-Lag) Start RPM" address="1280"/>
<table name="Desired Idle RPM with AC on" address="146c">
</table>
<table name="High Intake Air Temp Idle Speed Target" address="1e10">
</table>
<table name="Wastgate Solenoid Activation RPM" address="1668">
</table>
<table name="Speed Limit" address="118e">
</table>
<table name="Injector Scaling" address="1106"/>
<table name="Min Coolant Temp for Closed Loop" address="11aa"/>
<table name="Boost Cut Delay Timer" address="119a" scaling="Time"/>
<table name="Boost Desired Engine Load # 4" level="1">
<table name="RPM"/>
</table>
<table name="Max Wastegate Duty # 4" level="1">
<table name="RPM"/>
</table>
<table name="MAF Scaling" address="2a06" scaling="AirFlow8">
<table name="Load" address="5b78" elements="21"/>
</table>
<table name="MAF Smoothing Table" address="2a22">
</table>
<table name="Air Temperature Compensation" address="2a3e" scaling="uint8">
<table name="Degrees" address="5e5e" elements="8"/>
</table>
<table name="Barometric Pressure Compensation" address="2a51">
<table name="Atmosphere Pressure" address="5b66" elements="4"/>
<table name="RPM" address="5bac" elements="9"/>
</table>
<table name="Idle Stepper Look-up Table" address="3a35">
<table name="Throttle Position" address="5ee2" elements="8"/>
<table name="RPM" address="5efc" elements="27"/>
</table>
<table name="Knock Sensor Filter Map 1" address="3e69">
<table name="TAR" address="60b4" elements="12"/>
<table name="RPM" address="6094" elements="11"/>
</table>
<table name="Knock Sensor Filter Map 2" address="3f25">
</table>
<table name="Knock Sensor Filter Map 3" address="3fe1">
</table>
<table name="Knock Sensor Filter Map 4" address="409d">
</table>
<table name="Knock Sensor Filter Map 5" address="4159">
</table>
<table name="Knock Sensor Filter Map 6" address="4215">
</table>
<table name="Knock Sensor Filter Map 7" address="451f">
</table>
<table name="Knock Sensor Filter Map 8" address="45db">
</table>
<table name="Knock Sensor Filter Map 9" address="4697">
</table>
<table name="Knock Sensor Filter Map 10" address="4753">
</table>
<table name="Knock Sensor Filter Map 11" address="480f">
</table>
<table name="Knock Sensor Filter Map 12" address="48cb">
</table>
<table name="MAF Sensor Filtering" address="1108">
<table name="Load"/>
</table>
<table name="MAF Size" address="110c"/>
<table name="Boost Enhancement Enrich/Enlean (Anti-lag) Map" address="36cd">
<table name="Load" address="5ce8"/>
<table name="RPM" address="5cb6"/>
</table>
<table name="Boost Enhancement Adv/Ret Map 1 (Anti-lag)" address="33bd">
</table>
<table name="Boost Enhancement Adv/Ret Map 2 (Anti-lag)" address="3545">
</table>
<table name="Min Temp for Full Boost Control" address="1e06"/>
<table name="Boost Enhancement (Anti-lag) Stop RPM" address="1282"/>
<table name="Boost Enhancement (Anti-lag) Table" address="308e">
<table name="RPM" address="5c48"/>
</table>
<table name="MUT table" address="3f314" type="3D" level="1" scaling="Hex16">
<table name="X" type="Static X Axis" elements="16" scaling="Hex16">
<data>4</data>
<data>6</data>
<data>8</data>
<data>A</data>
<data>C</data>
<data>E</data>
<data>10</data>
<data>12</data>
<data>14</data>
<data>16</data>
<data>18</data>
<data>1A</data>
<data>1C</data>
<data>1E</data>
<data>0</data>
<data>2</data>
</table>
<table name="Y" type="Static Y Axis" elements="32">
<data>3f314</data>
<data>3f334</data>
<data>3f354</data>
<data>3f374</data>
<data>3f394</data>
<data>3f3B4</data>
<data>3f3D4</data>
<data>3f3F4</data>
<data>3f414</data>
<data>3f434</data>
<data>3f444</data>
<data>3f474</data>
<data>3f494</data>
<data>3f4B4</data>
<data>3f4D4</data>
<data>3f4F4</data>
<data>3f514</data>
<data>3f534</data>
<data>3f554</data>
<data>3f574</data>
<data>3f594</data>
<data>3f5B4</data>
<data>3f5D4</data>
<data>3f5F4</data>
<data>3f614</data>
<data>3f634</data>
<data>3f654</data>
<data>3f674</data>
<data>3f694</data>
<data>3f6B4</data>
<data>3f6D4</data>
<data>3f6F4</data>
<data>3f714</data>
</table>
</table>
<table name="2 byte load high bit" category="Misc" address="3f316" type="1D" level="1" scaling="Hex16"/>
<table name="2 byte load low bit" category="Misc" address="3f31a" type="1D" level="1" scaling="Hex16"/>
<table name="LeanSpoolEnable" category="Misc" address="1280" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="LeanSpoolDisable" category="Misc" address="1284" type="1D" level="1" scaling="RPMStatLimit"/>
</rom>
Old Oct 26, 2009 | 05:48 PM
Bmf's Avatar
Bmf
If you havent yet, you need to change the values in the mut talbe so evoscan can log from bolth places. Theres a thread on this with all the ecu codes so you can pick yours and put in the values for load,rpm and air flow.
Old Oct 26, 2009 | 05:57 PM
Bmf's Avatar
Bmf
https://www.evolutionm.net/forums/ec...te-thread.html This is were you can find you ecu code with the values you need. Hope this helps.
Old Oct 26, 2009 | 10:36 PM
fostytou's Avatar
EvoM Community Team
also, see the ecu wiki in my sig for more info on how that all actually works
Boosted Tuning
Aug 26, 2023 10:14 PM
richardjh
Jul 28, 2017 03:49 PM
PPM
Apr 2, 2015 09:35 AM
Mattjin
Oct 11, 2009 03:11 AM
monsta
Jun 15, 2009 01:14 AM
