TephraMod Knock CEL Flash discussion
Old Oct 28, 2009 | 04:15 AM
Biggy VIII's Avatar
slow 3
fast 6
load 100
Knock CEL Flash time 0.304
3 knocks begin to pull timing. I tune my car so that i prefer pull timing myself if it is necessary. If ECU pulls timing itself - something is wrong.
6 knocks begin to pull octane value and more ignition. Definetly time to lift...
Anyway its difficult to harm an engine under load 100.
RPM rise really fast so 1000ms or more setting make CEL stay flashing for a whole second even if there is no knock anymore, for example in 1st and 2nd gear on AX. CEL flash time of 304ms gives me a clear representation if knock really continues or it was a single occasional event.
Old Oct 28, 2009 | 07:45 PM
GotWheelHop's Avatar
I set mine at 3 for slow flash, 6 counts for fast, load over 120(sometimes get light tip-in knock) with 500ms.
Old Dec 23, 2009 | 09:26 AM
speifer's Avatar
Originally Posted by acamus
I have found that the problem is in EGR advance addition, I have tried to zero the EGR advance map and the problems went away in that region. I believe they are too agressive. I have EGR enabled in Periphery bits.
Acamus, could you elaborate? I'm not familiar with tip-in-knock, but I'm guessing its knock that occurs at a low rpm as load starts to come up. Can that be fixed by adjusting the EGR advance map?
Old Jun 22, 2012 | 10:48 PM
freethriftyz's Avatar
bump. I know holy thread revival...but mine is set to 4 and I get flashes almost every day. Is that something people just live with? Does fluctuate with sh!tty/non sh!tty gas, but it's usually always there.
not once the fast light though, which is set to eight. Slow one...everyday.
Old Jun 27, 2012 | 09:44 AM
EvocentriK's Avatar
I dont like any knock and have been able to tune it basically all out. I can log for 30 mins doing a hills run and have maybe 5 incidences of 1 counts, maybe 1 or 2 2 counts. Never on WOT over say 3500 rpm, I tuned all that out. Maybe my engines just quiet I dont know. I use 3 and 6 at 500ms. Haven't seen it flash in awhile.
Old Jun 27, 2012 | 10:48 AM
Raptord's Avatar
Spoolup is the one area where I get flashes once every 3-5 pulls or so. I'll need to check out the EGR advance mentionned above.
My settings:
Slow: 3
Fast: 6
Duration: 300ms (allows me to see if it goes away quickly or if it persists)
min-load: 100 IIRC
Old Jun 27, 2012 | 11:34 AM
charlie.tunah's Avatar
^same here, although my duration is set to 1000ms. When it hits 6, its a no brainer though. Completely falls on its face @ wastegate pressure.
Old Jun 28, 2012 | 07:50 AM
Jeff_Jeske's Avatar
I have mine set to 4 & 6 with load set to 200.
When my car was stock I often saw knock levels much higher so I'm not concerned. Setting it at 200 eliminates phantom knock
Old Jun 28, 2012 | 08:31 AM
Raptord's Avatar
Doesn't eliminate it, just keeps the CEL from flashing when it occurs
Ferp
Mar 11, 2017 09:50 AM
CtSilver03Evo
Cobb AccessPORT
Dec 14, 2016 12:54 PM
4b11slayer
Oct 18, 2016 09:36 AM
EvilEvolution8
Jul 13, 2016 06:58 AM
DarkerStars
May 12, 2012 11:11 PM
