Urgent! need help!!
Old Nov 2, 2009 | 02:29 PM
jrsimon27's Avatar
Urgent! need help!!
i was trying to upload a flash from another evo9 to my evo9 the thing is that i flashed the car know the car wont start what do i do?
i tried burning the oem.hex file back to the car but it gives me an error to see the log file?
i need help
thanks guys
Old Nov 2, 2009 | 02:37 PM
MR Turco's Avatar
Did you pull the stock rom first? Did you copy over the immobilizer number?
Old Nov 2, 2009 | 02:41 PM
jrsimon27's Avatar
mrturco i pulled the stock rom first i have it saved the thing is that i didnt copy over the immobilizer number know what do i do?
Old Nov 2, 2009 | 02:43 PM
jrsimon27's Avatar
iam know copying the inmbolizer code but the thing is that ecuflash says an error has occured when i try to burn it back to the ecu?
Old Nov 2, 2009 | 02:47 PM
MR Turco's Avatar
is the battery dead from trying to start it too many times? Try to jump the battery from a running car, wait 5 minutes and try to write the rom again.
Old Nov 2, 2009 | 02:49 PM
jrsimon27's Avatar
mr turco the battery is ok
i will wait 5 min and i will burn up the oem.hex
ok
Old Nov 2, 2009 | 02:51 PM
MR Turco's Avatar
Copy the text from ecuflash where it failed, in the log section on the right of the table list.
Old Nov 2, 2009 | 02:54 PM
jrsimon27's Avatar
ok what i did right know was that i tried to read the rom in the ecu this is what it gave me:
[16:53:02.680] Using interface OpenPort 1.3 Mitsubishi TX35YQfo3484f6d5f39ef7d1fffefa8325ac762852c395e3
[16:53:05.135] sending init sequence 1 (0001)
[16:53:08.427] sending init sequence 1 (0003)
[16:53:11.718] sending init sequence 1 (FFFF)
[16:53:14.479] no response to any known code
[16:53:14.479] interface close
Old Nov 2, 2009 | 02:58 PM
jrsimon27's Avatar
why wont it respond to any code i cant even read the new hex that i burned?
Old Nov 2, 2009 | 03:08 PM
MR Turco's Avatar
Battery isn't charged enough or the car isn't in the On position-not started
Old Nov 2, 2009 | 03:13 PM
Fourdoor's Avatar
If he has the wrong security code loaded, will the ECU even recognize that the key is in the on position? I thought that this was the great danger of just uploading someone else's ROM without changing the security code...
Keith
Old Nov 2, 2009 | 03:14 PM
MR Turco's Avatar
car wont start but you can flash as far as i know. the "great danger" is writing a rom over the stock rom without pulling it first which means you just wrote over the immobilizer code.
Old Nov 2, 2009 | 03:15 PM
jrsimon27's Avatar
so what do you guys mean the battery is fulled up
which is the security code your talking about?
Old Nov 2, 2009 | 03:16 PM
jrsimon27's Avatar
nope it wont flash nothing it wont even read the rom that i uploaded why is this??
Old Nov 2, 2009 | 03:19 PM
KevinD's Avatar
its because the battery is to low.... like people have been saying. throw a charger on it, turn off any stereo stuff and try again. if that doesn't help check your fuses. i've popped a fuse from turning a car off in the middle of a flash on accident.
