AT/SST/CVT MUT communication
Old Nov 7, 2009 | 11:40 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
I have started to decipher AT part of mitsu code, so mainly GTA and CT9W shall benefit from this.
But I see potential for X guys.
So far I have found in 88780004:
MUT_REQUEST_0 = AT_MUT_UNK0 = constant reply 0x81
MUT_REQUEST_1 = AT_MUT_UNK1 = constant reply 0x45
MUT_REQUEST_2 = AT_MUT_UNK2 = constant reply 0x5
AT ECU ID probably
Now all MUT request > 2 are taken from AT_MUT_Table. Last one is MUT_REQUEST_AD.
AE-FF are AT MUT commands. 0xFC seems to clear AT DTC's
Now the only outstanding issue is how to initialize.
Old Nov 7, 2009 | 12:19 PM
0xDEAD's Avatar
Good stuff. How popular is the 4g63 bolted to an AWD transmission in your country?
Old Nov 7, 2009 | 07:15 PM
Ceddy's Avatar
Acamus, you sure it doesn't do a 5 Baud Init?
Almost all the ISO ecus use a 5-Baud Init.
The H8 5 Baud Init is impossible to follow.
Baud isn't changed to 5, instead it does a reverse Bit-Bang by checking if the K-Line is Hi/Low every 200 mS.
The Init Response is spaghetti code, but can be found by searching for bytes loaded into the TX buffer.
MUT sends: 55 EF 85
OBD sends: 55 08 08
I'm not sure which CPU the AT TCU uses, but if you found the code in a ECU with the same CPU the code may match.
Since the 5 Baud Init isn't in the code in Byte form, its easiest to find by setting up a loop and sending all 256 combinations.
Old Nov 7, 2009 | 07:27 PM
logic's Avatar
Since we're playing with init codes, has anyone spent any time with the 2g or Evo SRS ECU, by any chance?
(Ask me about my book: "Thread Hi-Jacking for Fun and Profit". )
Old Nov 7, 2009 | 10:57 PM
acamus's Avatar
MUT sends: 55 EF 85
OBD sends: 55 08 08
Wakeup sequence is still valid also for AT part.
Old Nov 7, 2009 | 11:21 PM
acamus's Avatar
If you are asking about EVO's, its rare. One can see more Eclipses thou.
4G63 on 2WD can be seen more frequently.
But we are speaking about ~1% market share of all sold cars in Slovakia for mitsu.
Old Nov 8, 2009 | 02:58 AM
acamus's Avatar
Starting point for SRS is the OBD pinout
OBD Mitsu pinout:
1 Diagnosis control line
2 J1850 (+) line
3 Suspension - ECS -
4 Gnd
5 Gnd
6 Transmission - ELC-4/5AT
7 К-Line (ISO 9141)
8 Brake – ABS
9 ETACS: Pulse signal only
10 J1850 (-) line
11 Air Conditioner - Full Auto AC
12 Air Bag – SRS
13 Cruise Control – ASC
14 Vehicle speed signal
15 L-line (ISO 9141)
16 Power supply +12V
21 Traction – TCL/4WD
22 Steering - 4WS/ECPS
25 ECU
26 ECU programing
27 Transmission ECU programming
32 Adapter identification
Old Nov 8, 2009 | 06:32 AM
logic's Avatar
acamus, I've added that list to the wiki. Thanks for reminding me that I need to check my service manual from time to time.
Old Nov 11, 2009 | 01:33 AM
acamus's Avatar
So I have found some usefull AT MUT IDs
MUT_AT_0B_ADC_CHANNEL_11
MUT_AT_80_ADC_CHANNEL_1B
MUT_AT_81_ADC_CHANNEL_1D
MUT_AT_82_ADC_CHANNEL_1E
MUT_AT_83_ADC_CHANNEL_1F
MUT_AT_84_ADC_CHANNEL_1A
MUT_AT_85_ADC_CHANNEL_19
MUT_AT_86_TRANSMISSION_TEMPERATURE
MUT_AT_87_ADC_CHANNEL_1
MUT_AT_88_ADC_CHANNEL_18
MUT_AT_89_ADC_CHANNEL_12
Old Nov 14, 2009 | 11:53 PM
acamus's Avatar
I have verified that AT_MUT_86 is transmission temperature
AT MUT Table for 88780004 EVO IX GTA
Code:
<table name="AT MUT table" category="Misc" address="7F784" type="3D" level="1" scaling="Hex16">
		<table name="X" type="Static X Axis" elements="32" scaling="Hex16">
			<data>-</data>
			<data>0</data>
			<data>-</data>
			<data>1</data>
			<data>-</data>
			<data>2</data>
			<data>-</data>
			<data>3</data>
			<data>-</data>
			<data>4</data>
			<data>-</data>
			<data>5</data>
			<data>-</data>
			<data>6</data>
			<data>-</data>
			<data>7</data>
			<data>-</data>
			<data>8</data>
			<data>-</data>
			<data>9</data>
			<data>-</data>
			<data>A</data>
			<data>-</data>
			<data>B</data>
			<data>-</data>
			<data>C</data>
			<data>-</data>
			<data>D</data>
			<data>-</data>
			<data>E</data>
			<data>-</data>
			<data>F</data>
		</table>
		<table name="Y" type="Static Y Axis" elements="30">
			<data>AT_MUT0X</data>
			<data>AT_MUT1X</data>
			<data>AT_MUT2X</data>
			<data>AT_MUT3X</data>
			<data>AT_MUT4X</data>
			<data>AT_MUT5X</data>
			<data>AT_MUT6X</data>
			<data>AT_MUT7X</data>
			<data>AT_MUT8X</data>
			<data>AT_MUT9X</data>
			<data>AT_MUTAX</data>
			<data>AT_MUTBX</data>
			<data>AT_MUTCX</data>
			<data>AT_MUTDX</data>
			<data>AT_MUTEX</data>
			<data>AT_MUTFX</data>
			<data>AT_MUT10X</data>
			<data>AT_MUT11X</data>
			<data>AT_MUT12X</data>
			<data>AT_MUT13X</data>
			<data>AT_MUT14X</data>
			<data>AT_MUT15X</data>
			<data>AT_MUT16X</data>
			<data>AT_MUT17X</data>
			<data>AT_MUT18X</data>
			<data>AT_MUT19X</data>
			<data>AT_MUT1AX</data>
			<data>AT_MUT1BX</data>
			<data>AT_MUT1CX</data>
			<data>AT_MUT1DX</data>
		</table>
	</table>
Attached Thumbnails AT/SST/CVT MUT communication-at_mut_table.jpg
Old Nov 29, 2009 | 10:42 AM
acamus's Avatar
It seems I am all alone in this quest
MUT_B4 0x40 - Transmission Switch Position P - park as Mattjin have posted
MUT_B4 0x80 - Transmission Switch Position R - Reverse as Mattjin have posted
MUT_B3 0x1 - Transmission Switch Position N - Neutral
MUT_B3 0x2 - Transmission Switch Position D - Drive
MUT_A8 0x80 Transmission Switch Position 3
MUT_A8 0x40 Transmission Switch Position 2
MUT_A8 0x20 Transmission Switch Position L
MUT_A8 0x2 Output Shaft Speed Pulse
MUT_A8 0x1 Input Shaft Speed Pulse
MUT_AA 0x10 - Break switch - correct
Old Nov 30, 2009 | 08:49 AM
fostytou's Avatar
EvoM Community Team
Oh no, not the break switch!
Thanks for your continuing efforts. Do the drive/neutral flags apply to manual cars as well or are they specifically flagged based off the TCU?
Old Nov 30, 2009 | 02:02 PM
logic's Avatar
FYI, I've been updating the wiki with these as acamus posts them. Acamus, I'm afraid you're going to be pretty lonely working on the A/T stuff.
Also, there's a lot of other dev-related stuff (part numbers, schematics, pinouts, etc) that I've been trying to consolidate on the wiki, just in case anyone else cares about this kind of thing:
http://evoecu.logic.net/wiki/ECU_Development
Old Nov 30, 2009 | 07:26 PM
knochgoon24's Avatar
Hmmmm. I wonder how much if this is similar to the DSM auto transmission.
Old Nov 30, 2009 | 09:34 PM
acamus's Avatar
I have disassembled Galant/Lancer/Eclipse/EVO AT ECU, they are all the same, in the sense of MUT requests but unfortunatelly I do not have H8 AT ECU so I cannot confirm.
Maybe you can simply connect the cable and test it out
