Tactrix Cable Issue
Old Nov 19, 2009 | 05:46 PM
NotAnEvoOwner's Avatar
Tactrix Cable Issue
Looked on here still havent found an exact answer. I purchased this cable from Evoscan, OpenPort 1.3U, and when i hook it up to my evo 9, all the ACD lights bling and ABS, or just the tarmac light. I have evoscan 2.6 installed. Any ideas or answers would help. Bought the cable a week ago if that helps.
Old Nov 20, 2009 | 12:58 AM
churchja's Avatar
If you are getting the ACD ans ABS blinking lights (or just the tarmac lights) w/evoscan 2.6 installed then it indicates that it is working. Are you having any other issues? logging is OK? connections? Not clear on what is your question.
Jay
Old Nov 20, 2009 | 02:11 PM
OO well i hook it up and try to connect with evoscan to log and it cant connect for whatever reason, just keeps trying to reconnect.
Old Nov 20, 2009 | 03:07 PM
alicea8541's Avatar
When working correctly the 1.3U will blink all three ACD lights plus ABS until you are doing above 10 mph. Then it will stop blinking and only the 1 ACD light will be on, whichever one you have it set to.
Old Nov 23, 2009 | 08:48 AM
Understood, but evoscan will not let me connect for whatever reason, it just keeps going through the connection cycles, but never actually connects to the ecu.
Old Nov 23, 2009 | 05:26 PM
Evo_Jay's Avatar
Can I have a lil history on the car? Any chance it has a modded ROM loaded up?
What is your baudrate in evoscan?
Old Nov 23, 2009 | 05:27 PM
SyZyGy1394's Avatar
You have the wrong drivers....
I was using my friends older tactrix for a while and then when I got my own, it never connected. So I reinstalled the drivers and voila!
Old Nov 23, 2009 | 05:38 PM
4RETECH's Avatar
Are you sure it is openport 1.3 and not 2.0.
I bought one two weeks ago and it was a 2.0.
Old Nov 24, 2009 | 07:53 AM
That could be the issue cause i was using my friends older cable and then i went out and got one myself. So i'll give that a go and see what happens.
Old Nov 26, 2009 | 01:22 PM
Ok, so i uninstalled both my evoscan's version 2.4 and 2.6 and my ecuflash. Restarted, reinstalled evoscan 2.6 and the drivers. Still no luck.
Anyone have any other suggestions?
Old Nov 26, 2009 | 01:25 PM
Evo_Jay's Avatar
What kinda car? Is there a chance a modded ROm is loaded to it?
Old Nov 27, 2009 | 10:05 AM
SyZyGy1394's Avatar
Also make sure your car has enough voltage. I was surprised that I had to actually start my car and let it run for min to build up some juice before it would connect. What surprised me was that I just drove my car the day before.
Old Nov 27, 2009 | 12:08 PM
G20's Avatar
G20
before you try to connect, open the wideband dropdown menu in evoscan and make sure no wideband is checked.
Old Nov 30, 2009 | 10:46 AM
Heres what i have for the wideband options.
Old Nov 30, 2009 | 11:01 AM
SyZyGy1394's Avatar
Wait, can you even get ecuflash to test write or read?
