Why cant read the ECU?
Old Nov 27, 2009 | 09:41 AM
crazy_ugly_coyo's Avatar
Ths is what Im getting
TX277yZk95c3f4d53675fa0484d9da731966815fa5e3edb3 [10:34:01.300] sending init sequence 1 (0001)
[10:34:04.550] sending init sequence 1 (0003)
[10:34:07.800] sending init sequence 1 (FFFF)
[10:34:10.534] no response to any known code
[10:34:10.534] interface close
so why does it hate me so? I can hook up my obdII code reader and everything is happy. Im using a 1.3 tatrix cable
Old Nov 27, 2009 | 09:55 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
It usually happens when white connector is unplugged,
does it work with evoscan/mitsulogger?
Old Nov 27, 2009 | 10:04 AM
joshesh's Avatar
if you dont have enough voltage on your battery you wont be able to use a logger or ecuflash... try charging or putting in a new battery with a verified voltage around 13v and you should be good as long as your cable is plugged in correctly and your computer is working properly.
Old Nov 27, 2009 | 10:08 AM
todd6027's Avatar
try it with the engine running or if it was tuned previously try the unlocker
Old Nov 27, 2009 | 10:13 AM
jmcmill3's Avatar
X2 had this problem, running the car for a couple secs before i connected fixed the problem
Old Nov 27, 2009 | 11:58 AM
I tried my old ECU and it fired up, so now i threw the new one on and still no luck. How do I run the unlocker?
Old Nov 27, 2009 | 12:08 PM
Ive tried running the unlocker and still no luck!
Old Nov 27, 2009 | 12:16 PM
What are the chances BoombSlang messed the harness??
OK here the deal, this is a 2001 Eclipse with a swapped evo motor. It'll start with my stock ECU but not this one, so in order to delete the immobilizer I need to flash it...... well I cant connect so any ideas?
Old Nov 27, 2009 | 12:21 PM
G20's Avatar
G20
if it locked you can still flash it, just cannot read from it before you flash.
Old Nov 27, 2009 | 12:27 PM
buchnerj's Avatar
What operating system are you using to run your ECUflash? I had this same exact problem on my OSX Macintosh laptop, I switched to my Dads XP SP2 laptop and it worked. I also use the 1.3U Tatrix, so maybe it is a problem with the Mac version of ECUflash and the 1.3U cable...
Old Nov 27, 2009 | 12:42 PM
its a 1.3 cable and Windows XP SP2. I can read the ECU using EvoScan but no luck otherwise.
Like I said I can read my old ECU but not the Evo ECU... grrrrrrrrrrrr!
Old Nov 27, 2009 | 01:27 PM
Evo_Jay's Avatar
If you can read with EvoScan, then read your ROM, use ECUflash to disable the immob, then try to write the immob disabled ROM with EvoScan
Old Nov 27, 2009 | 10:51 PM
I cant read with either Evo Scan or ECU Flash. I have since tried a new ECU and still am ending up with the same issue.
Any chance that white plug is faulty?
Old Nov 28, 2009 | 11:10 AM
todd6027's Avatar
are you sure the ecu pinouts are not different
Old Nov 28, 2009 | 04:00 PM
They are different hence the boom slang
