ECUflash DIY cable
Old Nov 28, 2009 | 08:41 AM
boczo777's Avatar
ECUflash DIY cable
since cable looks pretty simple, usb plug i can just have from old mouse or whatever, just bought obd2 plug with terminals for 8$ shipped and this white flash plug got only one pin i can just slide terminal on it, why cant I find wiring diagram how to connect all of those myself??? nobody tried it yet???
Old Nov 28, 2009 | 09:22 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Here is your answer.
Old Nov 28, 2009 | 10:15 AM
Deepnine's Avatar
dont forget to connect the red and black wire.
Old Nov 28, 2009 | 10:42 AM
boczo777's Avatar
wow, www.limitless.co.nz cable looks way less complicated, anyways, any description to that diagram???
Old Nov 28, 2009 | 10:46 AM
EvoDan2004's Avatar
you should just support the hole group who makes this possible and buy a real cable.
Old Nov 28, 2009 | 10:48 AM
evofabulous's Avatar
looks way cheaper than buying one! i would do it too but i already have one
Old Nov 28, 2009 | 10:57 AM
mt057's Avatar
I believe that even if you make one it will not work with ecuflash. You have to have a special something to make it recognize the cable.
Thank you amacus I mixed them up.
An assembled cable is definetly worth buying.
Old Nov 29, 2009 | 10:51 AM
logic's Avatar
But if he wants to flash, I believe it's a "partial" answer. Doesn't EcuFlash check both the EEPROM's product ID and serial number? I might be assembling an extra cable soon, so I'll have to test this. (Honestly, we're at the point where someone might as well just write up an article for the wiki with a parts list and basic instructions for the 1.3 cables, since the OpenPort 2.0 cables are all Colby sells now anyway.)
mt057: are you sure Hamish added cable validation to EvoScan, and you're not thinking of EcuFlash? It's been a while since I checked, but I didn't think it cared.
boczo777: The "limitless" (EvoScan) cables are roughly similar to the OpenPort 1.3 cables that acamus posted the schematic for; he's made a couple of pin adjustments, if memory serves, but nothing too radical. They both use an FT232 chip under the hood for providing the serial interface; I'm afraid it's not as simple as hacking the plug off of a mouse cable, and directly wiring a few things; you need a serial interface as well. An FT232RQ is only $4.50 from DigiKey, so it's not an expensive addition (all the components on that drawing come to a little less than $10, so it's not that big of a deal; you're really paying for the excellent packaging that's been done).
Old Nov 29, 2009 | 11:14 AM
acamus's Avatar
Yes, they use some sort of "cable verification", nevertheless I cannot tell much bout boczo's electronic literacy, so I have just pointed to the schematics he wanted.
Anyway $8 for plug + $10 + PCB + shipping + time, it seems to me assembled cable is worth it, but I cannot tell how valuable boczo's time is
lbwilliams44
Jul 6, 2020 03:32 AM
evo8sk8
Mar 17, 2014 08:07 PM
Robdeep3
Jul 29, 2013 01:53 PM
maxsideburn
Jun 7, 2010 07:08 AM
philr8
May 13, 2010 02:35 AM
