some major idle issues on SD-0015 map
Old Dec 1, 2009 | 05:42 PM
EvoDan2004's Avatar
i hope this sensor is good. mitsu parts says its 282.20 i dont know if i have the right pn or not but WOW.
any idea why it would run much better on the initial map sensor swap and then when i shut it off it went back to being very bad??
Old Dec 2, 2009 | 12:09 PM
EvoDan2004's Avatar
i just did another boost leak test. this car has 0 leaks.
im going to go log the icv thing now.
Old Dec 2, 2009 | 06:50 PM
EvoDan2004's Avatar
ok. well we got it idling somewhat. its around 900rpm. but its extremely rough. afr's are 10.8s to 11.1 at idle.
the car does not want to stay running and will stall out sometimes. my guess is its because of the afr its seeing. right or wrong????
the car has a brake up issue to but i want to log it tomorrow and check something.
until then anyone with any more help??
EDIT
isc steps i logged it. it did nothing at all. isc steps 61 that was it. it did not move at all. weather i blip the gas or not it was 61 the hole time. is that correct???
Old Dec 3, 2009 | 09:42 AM
Oracle1's Avatar
try reducing your injector latencies, at a guess remove 0.200 off your existing value in 11 and 14 volts range.
Old Dec 3, 2009 | 01:41 PM
EvoDan2004's Avatar
ok i will try it. right now its 11.72v is 0.984 and 14.06v is 0.744 your saying to go from .984 to .784 and .744 to .544???
Old Dec 3, 2009 | 02:12 PM
Oracle1's Avatar
yes, try the 14v only first, check the afrs and report back.
Old Dec 4, 2009 | 12:16 PM
EvoDan2004's Avatar
ok a few things.
i tried the .200 decrease. i got no changes on anything. still running in the 11.1/2 range.
now the other thing i wanted the check was when i blip the gas the car dumps fuel bad. low 10.2 afr range. the car sputters and breaks up as well.
anyways this map that i have that runs around 900rpm seems to not even be a SD map. but when i put the SD map in the car shoots up to 2500+rpm. but afr's are 14.5/9
Old Dec 4, 2009 | 01:33 PM
Oracle1's Avatar
What vacum are you pulling under idle?
Can you email/pm your rom and map so I can see the bigger picture with your map?
Old Dec 4, 2009 | 02:32 PM
EvoDan2004's Avatar
i dont know. i have a pos stri boost gauge that says 2 to 3 vac. and the omni 4 bar never read vac right.
back in the hay day on stock motor and the same cams it was around 9. so with a built 2.0L motor i guess its the same.
Old Dec 4, 2009 | 05:23 PM
EvoDan2004's Avatar
ok well the car is going back on the maf/stock setup. we are putting a stock map in it with the proper injectors and going from there.
Old Dec 5, 2009 | 08:03 AM
Oracle1's Avatar
you may well be hitting the 60 load cell on your timing table. that would explain the high idle.
good idea to check with maf and oem injectors. should iron out any other niggles.
Old Dec 5, 2009 | 09:29 AM
phenem's Avatar
What do you mean by this? Can you explain?
Old Dec 5, 2009 | 10:46 AM
Oracle1's Avatar
if you look at the 60 load cell on timing table it usually is around 15* +. Too much timing will raise the idle, it's a possibility.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
06Black
Feb 22, 2012 01:13 PM
okevolutionVIII
Aug 9, 2009 06:36 PM
