PO1400 Manifold differential pressure circuit malfunction
Old Dec 12, 2009 | 02:57 PM
Danieln's Avatar
Did somebody face this code?
Is the MDP (Manifold differential pressure circuit malfunction).
I get this code for some time and I do not know where is the problem.
What about the pressure into the MDP?Where it must be the right pressure situated?
I assume that is a problem with the wires into my ecu because also my map goes to pin 92 (same with MDP sensor)....
My MAP is working properly and I do not think that is a wiring issue.
Could be that the MAP and MDP into the same pin is the problem?
Old Dec 12, 2009 | 03:00 PM
Danieln's Avatar
Could be a vacuum leak?
Could the blow off cause this problem regarding the leak?
awdordie
Jun 15, 2017 10:00 AM
MegaTek29
Apr 29, 2013 09:51 PM
babaz7
Jul 18, 2012 09:19 AM
evoredy
Feb 7, 2009 05:38 AM
BadazzCR
Aug 23, 2008 07:40 AM
