Intrepid ECU?
Old Dec 19, 2009 | 09:10 PM
japanevo's Avatar
Intrepid ECU?
alright so here is the question for tonight.... i was told about a tear ago that one of the dodges had essentially the same ecu installed in it. i want to say it was the intrepid but i am not positive.... anyone have some incite on this?
Old Dec 19, 2009 | 09:18 PM
JohnBradley's Avatar
Ummm same ECU as what?
Old Dec 19, 2009 | 09:21 PM
erald01's Avatar
the dodges have the same ecu as the non turbo dsm's as i far as i know
Old Dec 19, 2009 | 09:33 PM
japanevo's Avatar
sorry about that. i was told some of the newer Dodge's had the same ecu as the EVO8's
Old Dec 19, 2009 | 10:16 PM
Ceddy's Avatar
The Dodge/Chryslers with Mitsu motors have Mitsu ecus.
Stealths have 3000GT ecus,
Colts have Mirage ecus,
etc.
And many ecus are compatible.
For example most export(non-JDM) 4-cylinder H8 ecus can be cross flashed with other export cars images.
The only way to tell if compatible is to compare same year ecu PCB Numbers, if they match they are most likely compatible.
I have no idea what newer Dodges have 4-cylinder Mitsu motors to check PCB Numbers against though.
Never cross flash an image with non-matching PCB Numbers, that usually bricks the ecu.
Old Dec 19, 2009 | 10:55 PM
MattS00's Avatar
The dodge stratus and chrysler sebring from the same model years as the 3g eclipse have an SH processor. However, the model year 2000 eclipse/stratus/sebring have an H8 based ecu. If I have read correctly the 4 cylinder ecu can be flashed with an evo 8 rom image. The stratus and sebring were made at the same factory that made the eclipse in Normal Illinois.
Old Dec 20, 2009 | 09:31 AM
steadly2004's Avatar
Only the stratus and sebring COUPE's do. No 4 door or convertible. (not correcting you, just adding info)
I have a stratus coupe, although I just swapped the entire ECU to an EVO one when I changed from auto to manual, the pinouts are the same (but missing the fuel solenoid and boost solenoid pinouts on the harness). Its all plug and play.
Old Dec 20, 2009 | 04:52 PM
japanevo's Avatar
OK then as a possible cheaper ECU option would be from a 2001 newer sebring or stratus 2dr. has anyone actually flashed an EVO ROM to one of these ECU's?
Old Dec 20, 2009 | 10:58 PM
MattS00's Avatar
I think so, but not positive. I don't have a 4 cylinder car, so I never really paid attention. Here is a starting off point for you.
http://www.club3g.com/forum/3g-eclip...load-here.html
Old Dec 21, 2009 | 01:40 PM
travman's Avatar
I pulled the rom off my fiances old 01 stratus coupe using the tactrix cable.... but never flashed anything back on for fear of f-ing her car up
Now she has a 350z track edition and i really wish there was open-source software for it - tuning software for those cars is down right dirty expensive.
Old Dec 21, 2009 | 06:27 PM
It runs the same, several people on club3g.com have used the EVO ROM in their stock ECU. I don't know if there are any drawbacks, but again the ECU is missing a couple pins.
rme0f1
AEM EMS
May 17, 2017 09:28 PM
greddy23
Oct 19, 2016 08:41 AM
jameswwt
Feb 15, 2016 05:59 AM
1squirrelly1
Nov 26, 2015 12:23 AM
OPENA(671)
Jun 29, 2013 07:13 PM
