ECU boost control mods for 90550001 ?
Old Dec 31, 2009 | 12:42 AM
AIK's Avatar
AIK
ECU boost control mods https://www.evolutionm.net/forums/ec...trol-mods.html is it impossible to realise or...? I could not find the necessary addresses anywhere.
Old Dec 31, 2009 | 11:01 AM
burgers22's Avatar
You could try running a 3 port solenoid in place of the stock setup. This gives me very good boost control. As you are in Russia, I guess you see a very big difference in temperature, you should be able to run with very low levels of correction and get a stable boost control, not that affected by the difference in winter and summer temps.
Old Jan 1, 2010 | 12:14 PM
AIK's Avatar
AIK
I used ECU boost control mods + 3-port GM on my 96530006 EDM car earlier.Now i am using Tv7+ ECU boost control mods + 3-port GM. I like the result - when weather changed from +20 to -20 dg. C boost changed from 1.40 to 1.42-43. I want repeat this result on 99860002 evo7 (3-port already instaled) . I need buy 96530006 ECU, I do not have other variants?
Old Jan 1, 2010 | 02:39 PM
rolly1818's Avatar
Registered User
9055 is an evo 7 rom, tephra should be doing V7 soon for this rom.
i dont see why 9653 cannot work on the evo 7 though.
Old Jan 1, 2010 | 03:30 PM
todd6027's Avatar
try it and you will find out
mrxx
May 15, 2014 10:29 AM
jameswwt
Jan 15, 2013 10:34 AM
VGergo
Apr 10, 2010 02:34 AM
racer135
Sep 23, 2009 07:55 PM
nj1266
Apr 6, 2007 08:10 PM
