Speed Density 2.0?
Old Sep 6, 2010 | 09:23 PM
  #121
03whitegsr's Avatar
I've got a couple races this next month, after that, I may try out my code and see how it does.
Old Sep 27, 2010 | 03:30 PM
  #122
Biggy VIII's Avatar
It would be really good if we could wire in second GM MAT for measuring IAT before turbo, so that MAF IAT WGDC Correction could work correctly in different ambient temperatures, as it does at non-SD roms. This correction is really important for Boost Control using stock ECU.
Old Sep 29, 2010 | 06:24 PM
  #123
turbooutlaw1976's Avatar
Also willing to be a test subject
I am also willing to test out SD 2.0. Please PM me with a download link if you want valuable feedback from some experienced tuners.
Originally Posted by 03whitegsr
Bumping this back up.
Willing to be an Alpha/Beta tester if there is anything coded up for 9653XXX6.
Old Sep 30, 2010 | 12:16 AM
  #124
And's Avatar
And
I'm available to test anything on the 9653xxx6 also using SD on a 2.3 at the moment
Old Oct 4, 2010 | 07:37 PM
  #125
black-dsm's Avatar
any updates?
Old Oct 5, 2010 | 07:26 AM
  #126
03whitegsr's Avatar
Most likely, I won't be working on this until January or so. Got to finish up my master's degree this semester and I made a horrible choice on classes. 30+ hours of homework a week. YEAH!!!
Old Oct 20, 2010 | 02:02 AM
  #127
justastockevo's Avatar
Originally Posted by l2r99gst
2. Ability to use an extra baro sensor at startup, for starting at different altitudes
3. Ability to use a different MAT temperature for startup, to prevent lean starting with heat soaked MAT sensors
  • I would suggest a configurable MAT temp subtraction from measured MAT temp
  • Configurable coolant temp above which correction occurs
  • Possibly a configurable decay rate or hold time for the corrected MAT temp.
Eric
to keep a thread alive...
does anyone know the voltage output of an oem baro at different pressures?
and is it different from GM's part #1600683.
also, as for heat-soaked startup, would only a coolant temp correction be enough?
say, run rich for XX seconds if coolant is above certain temp.
Old Dec 22, 2010 | 05:52 AM
  #128
Creamo3's Avatar
Bumping this one back to the top for 2011
I personally would love to test out a 3D VE table to fine tune some areas of the map. It seems w/ 2D tables when you make a VE change it may resolve a trouble spot you were targeting, but in turn can throw another part of your map out of whack. Any beta XML's that somebody would be willing to distribute out for testing purposes?
Old Dec 22, 2010 | 06:09 AM
  #129
And's Avatar
And
i'd love to test this also, some things that I've noticed with mine for everyday use are;
Warm start idle for the first 5 seconds after heat soak, (restart after driving around for a while) would be nice to get an if warm setting
but would defo love the 3D table
Old Dec 22, 2010 | 07:52 AM
  #130
i think we can use existing map sensor for this.
the logic for baro subroutine should be as following:
- read MAP value, make sure that rpm = 0
- subtract atmo pressure at 0 ft altitude from it
- use the resulting value for baro compensation
any comments please?
Old Dec 22, 2010 | 11:46 AM
  #131
03whitegsr's Avatar
There is a start up routine that goes through and clears out a bunch of variables, sets others to default values, basically a soft reset so the car will start from a known state. This would be the place to fit in such a static value. It would work, but I think there may be a better "live" way to do it.
You don't want to replace the main baro value though. You only want to replace the baro values that affect certain things. Other wise, you would cause fuel and timing problems.
Old Dec 22, 2010 | 05:58 PM
  #132
92LaserRs's Avatar
Id be up for testing this out as well when its ready.
Old Dec 23, 2010 | 09:36 PM
  #133
BEISSEN's Avatar
Ok I have one for someone since you all are pretty well knowlegeable, I got my SD setup completed 2 weeks ago well a week later it went to what we think a limp mode, the car wont rev past 3500 RPMs. We swapped in the MAF and Factory MAP and boom car came alive again. Thought it was the MAP now got a new MAP "omni power 4 bar" and well nothing still wont go past 3500 RPM's. My setup is simple.
Omni Power 4 bar MAP
Tapping into the Fuel Temp Sensor via advice from English Racing as the IAT have min differance from useing the Factory Fuel temp via the ECU. This is being done on Ecu Flash not Tephra Mods if that helps. I really could use any input as what to check or to do I have no logs and since its the holiday I cant do much until monday I left the car at the shop.
Old Jan 17, 2011 | 06:02 AM
  #134
SkyNight's Avatar
Guys are there news for 3d maps?
nj1266
Jan 25, 2026 01:43 AM
PIE-R
Dec 21, 2019 08:14 PM
mrfred
Jan 28, 2017 09:58 PM
r4p.t0x
Jun 29, 2014 10:17 AM
mrfred
Aug 14, 2009 07:17 PM
