Can't find solution - Ecuflash doesn't react for xml changes
Old Jan 27, 2010 | 11:47 PM
TJung's Avatar
Hey. My problem is that my Ecuflash doesn't reacting for .xml files changing. All the time I have the same tables, even when I copy modified xml's (for example tephra v5.1).
I've even tried to reinstall Ecuflash and still nothing :/
This is happening only on my new laptop with Vista Home Basic. On old laptop with Win XP everything is ok. Ecuflash 1.42.2595
Any ideas ?
PS. and one more: I am autodidact, so please forgive me guys, my english I hope everything is understa[ble]
Old Jan 28, 2010 | 07:10 AM
TouringBubble's Avatar
Do you have multiple versions installed? Maybe modifying XML on the wrong directory?
Old Jan 28, 2010 | 08:01 AM
TJung's Avatar
No, only one. I'm not sure - maybe Vista holds deleted xml's somewhere ?
Old Jan 28, 2010 | 10:32 PM
codgi's Avatar
I'd go with a no . So after you change the xml, have you ensured that the xml actually saved the changes? I know this sounds odd but that would be one thing to check.
Also are you changing the actual rom id.xml or the evobase<x> xmls?
Old Jan 28, 2010 | 11:45 PM
TJung's Avatar
I am not modyfing base xml's. I've exchanged them as You said: rom id.xml and the evobase<x>xml for v5.10 xml's.
Which inherits should using 88590015 with v5.10 ?
Old Jan 29, 2010 | 10:22 AM
TJung's Avatar
noone ?
Old Feb 4, 2010 | 07:47 AM
TJung's Avatar
Update. It's weird because with upgrading to V7, my Ecuflash is beehaving normal. All works, and it's reacting od .xml changing. Only with V5.10 is going bad
Old Feb 9, 2010 | 10:03 AM
03lances's Avatar
Maybe your user level was still set to beginner?
Old Feb 9, 2010 | 10:51 AM
TJung's Avatar
Nope I've tried everything. Weeeird
