Looking for ECU definitions
Old Feb 2, 2010 | 01:40 PM
ecktt's Avatar
Here are the hex files and Task info log for them.
The RS opens but has most of the Tables greyed out. I hope its as simple as a def file.
File Type: zip
File Type: zip
Old Feb 2, 2010 | 02:23 PM
todd6027's Avatar
try these either of these aint very common thats why they are not as well defined . evo7 base included
File Type: zip
File Type: zip
File Type: zip
Old Feb 2, 2010 | 04:17 PM
ecktt's Avatar
Whoa. Once again, your the man!
The RS worked out perfectly but the GT-A seems to still have a few isues. take look at the image. Most of the other table are the same.
Old Feb 3, 2010 | 02:07 PM
rolly1818's Avatar
Registered User
woe fellow trini!
if you need help PM me
Old Feb 3, 2010 | 04:37 PM
todd6027's Avatar
try the 80700010 one now attached above fixed
Old Feb 4, 2010 | 12:59 PM
ecktt's Avatar
I think the "Timing" section for the RS and GT-A are still off
Old Feb 5, 2010 | 10:28 AM
W2J's Avatar
W2J
http://geekmapped.com/forums/attachm...8&d=1258769673
I was able to patch the rom and update the def with correct MUT address with the help of Sub7, you need to reflash with the attachment. I have tested and confirm on three GTA's that it works.
Gerrard
Old Feb 5, 2010 | 11:53 AM
todd6027's Avatar
looks ok here , they are not stock someones been in there before .
Old Apr 7, 2010 | 11:25 AM
YaroRS's Avatar
good XML file with 2 set of ignition and fuel maps, mut table defined and some automatic gearbox functions.
File Type: zip
