Woot Woot FINALLY................ got the MapTracer to work. LOL
Old Feb 14, 2010 | 05:00 PM
hediki12's Avatar
i got mines to work yesterday.. reinstalled it and logged my 1 byte load an ecuload . of course that made the trace weird so i copied the 1byte data and dropped it under ecuload . now im just going to log my 1byte as ecuload so i dont have to copy and past so much.
Old Feb 14, 2010 | 11:34 PM
project_skyline's Avatar
Sweet I got it to work, Thanks frosty!!!
The only thing though, when I check WB02 it comes up in single digit numbers...
Old Feb 21, 2010 | 11:53 PM
nonschlont's Avatar
Finally got my laptop to cooperate w/ me, and got a clean v.7 rom running, so of course, it was time to see if I could get the map tracer to work for me... Thanks to fosty's efforts w/ the wiki, just got it to work w/ my v7 rom... Thank you!!! Well done, sir.
Old Feb 21, 2010 | 11:56 PM
tscompusa2's Avatar
Like mentioned in here already, the main reason everyones map tracer doesn't
work is because of the load value isnt in the log that it needs to show load on the map.
In v2.6, if you delete LoadCalc the map tracer stops working, yet on the beta 2.7 if you
dont log LoadMUT2Byte & RPMMUT2Byte it stops working.
So v2.6 = map tracer is looking for the log with LoadCalc, if this value doesn't exist in your
log it simply wont light up any cells in map tracer.
Example: If you were logging 2byte load and the map tracer didn't work in version 2.6 you would
change the 2byte load title in your log to "LoadCalc" and than it would work in map tracer.
Now with 2.7 it doesn't look for LoadCalc, the programmer now changed it so it looks for "LoadMUT2Byte & RPMMUT2Byte
Basically all you have to do is rename the title to the item you use for your load reading to correspond to either of the above and the map tracer will work.
Just change the log reference to the name. so if using 2.6 you'll change log reference to LoadCalc wherever youre logging your actual load your tuning with.
and with 2.7 LoadMUT2Byte & RPMMUT2Byte. its really that simple.
Old Feb 22, 2010 | 03:30 AM
hediki12's Avatar
^ exactly what I found out with v2.6. I just replaced the oadcalc formula with the 1byte formua n mut request number. N boom it worked
Old Feb 22, 2010 | 06:23 PM
Anyone have problems with WB02 not showing properly?
Old Feb 22, 2010 | 10:45 PM
tscompusa2's Avatar
WB02 isnt the external wideband, just fyi.
Old Apr 13, 2010 | 02:41 PM
So what do I have to change to see logged afr from external WB?
Old Apr 13, 2010 | 03:00 PM
tscompusa2's Avatar
nothing. you tic the left (wideband) and the loads light up. but be adviced from experience the RAW log is more efficient then a map tracer EVER will be. I do not recommend using map tracer. The raw log will give you play by play information. And when tuning the fuel map you dont want to just change the a/f where its being traced, you want to cover everything so you can assure a safe tune when the time comes to go through the gears.
Old Apr 13, 2010 | 05:32 PM
Ya thanks, this isn't my first bbq. I just wanted to get it working, i've been tuning with raw logs for 2 years now its just nice to have all the tools working right.
Old Apr 13, 2010 | 05:39 PM
tscompusa2's Avatar
if your map tracer isnt tracing sometimes you have to change the RPM settings on it from the drop down, etc.
Map tracer is good to dummy down the map when on the road tho i will say that. I use it for a reference sometimes as well when i get lazy. this is my first bbq with a actual GRAPHING map like ecuflash uses. I only ever used dsmlink back in 2007, so i had no experience with actual real tuning. I like the graphs better tho, gives more control over everything.
domyz
Dec 24, 2013 05:14 PM
drifterific
Sep 1, 2010 06:05 PM
drifterific
Aug 5, 2010 03:14 PM
ouminan
Jan 21, 2010 08:19 AM
