Break-thru: Reading ACD ECU with EcuFlash
Old Mar 26, 2010, 05:42 PM
  #181
colby's Avatar
The new version which supports the ACD / H8539FA correctly is here.
Old Mar 26, 2010, 06:12 PM
  #182
evonut270's Avatar
colby,i have tried this on the evo 6 engine ecu with the MH7203FA processor and still no luck
Old Mar 26, 2010, 06:18 PM
  #183
colby's Avatar
are you sure the CPU is not MH7202F?
can you show me a log indicating where it fails? it may be as simple as using H8539F .vs. H8539FA in the wrong instance...
Old Mar 26, 2010, 06:33 PM
  #184
Ceddy's Avatar
sba,
EvoScan now has support for ACD, and you can edit the RequestIds.
Would you have time to take some logs with some custom items? I could try finishing up ACD definition with new info.
Old Mar 26, 2010, 06:48 PM
  #185
colby's Avatar
I can probably add this to the Openport 2.0 stand-alone logging as well if you have any info.
Originally Posted by Ceddy
sba,
Old Mar 26, 2010, 06:51 PM
  #186
evonut270's Avatar
no its definatly a 7203FA on the later evo 6 TME i have the board right in front of me.i also sent you an email to support@tactrix.com
Attached Thumbnails Break-thru: Reading ACD ECU with EcuFlash-ecuflash-v1.43.2990.jpg
Old Mar 26, 2010, 06:56 PM
  #187
colby's Avatar
I can see from the image that you are using the wrong memory model. Change the memory model for your XML definition from H8539F to H8539FA and you should be good to go. Let me know about any other ROM definitions that also need this fix. There is no easy way for me to know which chip is being used in these various ROMs. Both kernels will work fine for reads...
Old Mar 26, 2010, 07:09 PM
  #188
evonut270's Avatar
i have changed the memorymodel in my XML but it still shows H8539F on the screen.it only seems to be this rom so far thats causing trouble
Old Mar 26, 2010, 07:19 PM
  #189
evonut270's Avatar
colby forgive my stupidity i replaced the rommetdata folder with my own iv since put the original back in and all is well
  #190
fixem2's Avatar
Can you read the ACD via this version of ECUFLASH with a 1.3 cable or is it 2.0 only?
Old Mar 26, 2010, 07:21 PM
  #191
colby's Avatar
2.0 only...
Old Mar 26, 2010, 08:04 PM
  #192
colby's Avatar
glad to hear it. you made me panic for a minute. i'm glad to finally have this H8 stuff completely working. spread the word to anyone who may still be stuck on H8 stuff.
Old Mar 26, 2010, 08:36 PM
  #193
evonut270's Avatar
I will do and thanks again. The only thing that does not work is flashing full roms over
Old Mar 27, 2010, 02:36 AM
  #194
merlin.oz's Avatar
I have just performed my first sucessful ACD+AYC ECU reflash.
Thanks Colby, very, very pleased.
edit: Colby, Did you receive the xml and ROM files I sent to Tactrix support?
Old Mar 27, 2010, 06:11 AM
  #195
Danieln's Avatar
Ecuflash 1422595 don`t work anymore after I try to install the beta ecuflash.
You know why??
I have Tactrix 2.0
Seems that the driver is corrupt or something for 2.0
Quick Reply: Break-thru: Reading ACD ECU with EcuFlash
