9366005 ALS table evo 8 jdm
Old Feb 13, 2010 | 10:01 AM
claudiumxg's Avatar
does anyone have correct als table adreses for this rom?
i only managed to make few values work, and run out of ideas
thanks
this is what i have-seem to be from a evo 7
<table name="ALS minimum vehicle speed to trigger" category="ALS" address="2210" type="1D" level="1" scaling="VehicleSpeed"></table>
<table name="ALS minimum coolant temperature to trigger" category="ALS" address="2212" type="1D" level="1" scaling="Temp"></table>
<table name="ALS minimum RPM to trigger" category="ALS" address="2214" type="1D" level="1" scaling="RPMStatLimit"></table>
<table name="ALS minimum load to trigger" category="ALS" address="2216" type="1D" level="1" scaling="Load16"></table>
<table name="ALS minimum time to trigger" category="ALS" address="2218" type="1D" level="1" scaling="TimeSec"></table>
<table name="ALS trigger valid time" category="ALS" address="221a" type="1D" level="1" scaling="TimeSec"></table>
<table name="ALS Load below which active" category="ALS" address="221c" type="1D" level="1" scaling="Load16"></table>
<table name="ALS active time limit" category="ALS" address="221e" type="1D" level="1" scaling="TimeSec"></table>
<table name="ALS Delay before air injection" category="ALS" address="2220" type="1D" level="1" scaling="TimeSec"></table>
<table name="ALS Delay before fuel injection" category="ALS" address="2222" type="1D" level="1" scaling="TimeSec"></table>
<table name="ALS Fuel injector time" category="ALS" address="2224" type="1D" level="1" scaling="TimeSec"></table>
<table name="ALS Air injection time" category="ALS" address="49e6" type="2D" level="1" scaling="Timesecbyte">
<table name="RPM" address="569a" type="X Axis" elements="9" scaling="RPM"></table>
</table>
Old Feb 14, 2010 | 06:52 AM
Danieln's Avatar
Here we go mate,
<table name="ALS minimum vehicle speed to trigger" category="Turbo" address="2212" type="1D" level="1" scaling="VehicleSpeed"/>
<table name="ALS minimum coolant temperature to trigger" category="Turbo" address="2214" type="1D" level="1" scaling="Temp"/>
<table name="ALS minimum RPM to trigger" category="Turbo" address="2216" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="ALS minimum load to trigger" category="Turbo" address="2218" type="1D" level="1" scaling="Load16"/>
<table name="ALS minimum time to trigger" category="Turbo" address="221a" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS trigger valid time" category="Turbo" address="221c" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Load below which active" category="Turbo" address="221e" type="1D" level="1" scaling="Load16"/>
<table name="ALS active time limit" category="Turbo" address="2220" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before air injection" category="Turbo" address="2222" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Delay before fuel injection" category="Turbo" address="2224" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Fuel injector time" category="Turbo" address="2226" type="1D" level="1" scaling="TimeSec"/>
<table name="ALS Air injection time" category="Turbo" address="4866" type="2D" level="1" scaling="Timesecbyte">
<table name="RPM" address="64c0" type="X Axis" elements="9" scaling="RPM"/>
</table>
Old Feb 26, 2010 | 03:24 AM
HxllxMan's Avatar
How about, did anyone was able to make it works on a USDM evo with the ALS hardware from JDM?
Boosted Tuning
Aug 26, 2023 10:14 PM
itzwolf
Mar 15, 2022 06:18 AM
chetrickerman
Oct 20, 2015 07:10 AM
PPM
Apr 2, 2015 09:35 AM
Piper747
Oct 9, 2010 01:14 PM
