omni 3 bar settings...i've searched
Old Feb 13, 2010 | 01:38 PM
Drill_Sergeant's Avatar
Veteran: Army
to anyone who can help:
I see settings for JDM/EVO X MAP sensors and also for Omni 4 bar.
Which of these am I SUPPOSED to use for the Omni 3 bar? I'm currently using the Omni 4 bar settings with the Omni 3 bar evoscan formula which as of now is giving me pretty good results.
Just double checking and making sure I am using the correct settings.
I saw someone asked this same question in the JDM MAP thread but no one replied.
Old Feb 13, 2010 | 03:33 PM
lan_evo_mr9's Avatar
Are you just logging boost or trying to run ECU Direct boost control or maybe SD?
Old Feb 13, 2010 | 05:19 PM
Veteran: Army
ecu direct boost with grimmspeed 3 port
Old Feb 13, 2010 | 07:57 PM
JohnBradley's Avatar
On the scaling you need to make a graph comparing voltage values from the 4 bar, 3 bar, and JDM 3 bar and see where they all overlay.
I will be doing a right up on the proper voltage scaling for most of the sensors (other than the JDM 3 bar and Omni4) here shortly. In the meantime you should be able to use the JDM 3 bar voltage scaling and be pretty close.
Old Feb 13, 2010 | 08:04 PM
Ceddy's Avatar
The Omni 3BAR matches the GM 3BAR with in 1-2%.
GM 3BAR:
EvoScan:
PSIG -> (x*0.17886) + 0.161 - 14.5
kPa -> ((5.0*x/255) + 0.01765)/0.01591
EcuFlash:
To Display -> x*0.31
To ROM -> x/0.31
(Not sure if Direct Boost uses 10-bit ADC scaling like SD or not)
Old Feb 13, 2010 | 08:43 PM
Veteran: Army
thank you JB and Ceddy
RelentlessEVO
Feb 9, 2017 01:34 PM
Raceghost
Sep 21, 2016 10:31 PM
Enyth
Apr 12, 2016 09:06 PM
black-dsm
Mar 7, 2016 05:38 PM
Evoryder
Dec 9, 2009 07:34 PM
