96531706 SD flashed P0125 fault
Old Feb 18, 2010 | 02:35 AM
nabilsx's Avatar
guys yesterday I installed the Omni 3bar map sensor I have and flashed the 96531706 SD tune, I changed the values in the xml to match the Omni 3bar setting but now I am getting this fault P0125 - Insufficient Coolant Temperature For Closed Loop Fuel Control., I am using fuel temp ADC as the input for MAT. I know it is some value in the table that I have to adjust, since I never had that issue with the 96420011 V5.10 before, yesterday I went SD and 96531706. I just searched the forum and so that this has been addressed before, I need to mention that yesterday I removed the Rear O2 and installed a wideband sensor in its place, can that be the reason for this problem?
PEACE
NAB
