How to log load with v7?
Old Feb 20, 2010 | 09:26 AM
hediki12's Avatar
just use load calc change the request to 41 and fuction to 1.2*x that way your map tracer will work .
or put this into your xml listed as data in evoscan
Code:
<DataListItem DataLog="Y" Color="" Display="Load 1Byte" LogReference="Load1B" RequestID="41" Eval="1.2*x" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="270" ChartMin="0" ChartMax="270" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Feb 20, 2010 | 11:10 AM
kruthles's Avatar
What are the advantages of logging 1byte over 2byte in v7?
I have also noticed that while logging 2byte and 1byte simultaneously the values are quite different at times.
For example in the same log where I hit 26psi my 2byte load was around 270-280 whereas my 1byte was showing 300-310.
Old Feb 20, 2010 | 11:16 AM
l2r99gst's Avatar
There are many different loads...uncompensated, baro compensated, and baro+temp compensated. I always forget which tephra made his 1byte load.
Edit: Just looked it up to confirm. Tephra's 1byte is uncompensated load.
For fuel, the baro+temp comp load is used
For timing, baro+temp is used unless IAT is above 77F. Then baro comp load is used.
Old Feb 20, 2010 | 06:56 PM
Nasty Evolution's Avatar
So far I still can not log 1 byte load with the methods posted on page 1. My load shows up at 1.2 on the graph.
Old Feb 21, 2010 | 09:09 PM
kruthles's Avatar
UPDATE:
My mismatch issue was mainly caused by having 1.2 in the "2byte to 1byte load factor" field in my v7 ROM and having 1.3 in the EvoScan eval.
Old Feb 22, 2010 | 08:02 AM
UPDATE:
So are you logging with 2 byte load in V7 just by changing the equation factor?
Old Feb 22, 2010 | 10:31 AM
SoCal Rally's Avatar
The XML definition for 1-byte load may only have been added in a version of EvoScan released after the v2.4 that you are using.
Try updating your EvoScan to the latest version i.e. v2.7 beta 5, and see if the 1-byte load field then appears in EvoScan:
http://www.limitless.co.nz/evoscan/EvoScanv2.7beta5.zip
EDIT: Hmm, the link for v2.7 Beta 5 doesn't seem to be working at the moment. You'll have to check if the link is back up later, or ask someone else for a copy, or log a support ticket:
http://www.evoscan.org/helpdesk/index.php?a=add
EvoScan v2.6 is available here:
http://www.limitless.co.nz/evoscan/EvoScanv2.6.zip
Old Feb 22, 2010 | 01:22 PM
kruthles's Avatar
Currently I am logging 1byte via the method explained in this thread.
If you want to log 2byte in v7 you have to modify the MUT table as you would any other ROM.
See https://www.evolutionm.net/forums/ec...te-thread.html for more information.
Old Sep 1, 2010 | 04:38 PM
VGergo's Avatar
What to do in Evoscan to coud log 2byte temp+baro comp load ? What to write in the Escan XML ? in the v7 9653 just change the MUT setting for that one ?
2-byte LOAD_Temp_and_Baro_Compensated
MUT00 = 898A
MUT01 = 898B
Old Mar 8, 2011 | 04:21 PM
deeman101's Avatar
Originally Posted by tscompusa
ive been researching it for awhile, so i know a good amount to get around the stock ecu. forget 2byte load, just log 1 byte
But does logging 1byte in tephra with that conversion factor give you compensated load or raw load?
Old Mar 8, 2011 | 04:26 PM
Raptord's Avatar
IIRC it gives you the same load that the fuel and timing BIGMAPS use, I'm not sure which one that is though.
redSLed
Jan 9, 2017 05:22 PM
ekizenbe
Sep 7, 2016 12:51 PM
roni4g63
Nov 14, 2015 11:45 AM
stunt2
May 25, 2012 01:46 PM
Seijuro
Mar 20, 2010 11:53 AM
