Connection Error
Old Feb 24, 2010 | 12:41 PM
silex's Avatar
Connection Error
I keep getting an initialization error and the cable won't connect to read or write to the ECU. It tries to connect 3 times and then errors out. It used to work, but I haven't used the car in 9 months since I was putting it back to stock. Some of the ECU wires had to be taped off since I tapped into them, but I don't see this being related.
I did a search and found out it could a plethora of things: bad cable (tried friends newer v1.3u cable on v1.42 with same issue), low voltage battery (started the car and tried connecting), wrong software version (v1.3m cable so I'm using v1.29a), ecu unlocker software (mine isn't but tried it anyways), etc. I tried it all and nothing works. I know the cable works since I can run the OBD2 software, connect, and reset CEL's. I tried the rest to no avail.
Any other suggestions? I need to get into the ECU since the car is back to stock, but the flash is not.
Old Feb 24, 2010 | 02:32 PM
fostytou's Avatar
EvoM Community Team
Put a charger on it, the starting the car thing doesn't work for me after some jerk at the tire shop left my car in the on position for 4 hours with a mini battery
Old Feb 25, 2010 | 08:42 PM
LGshow19's Avatar
try getting a new cable(1.3)... May upgrade to Ecuflash 1.42 as well.
Old Feb 26, 2010 | 05:40 AM
Monochrome's Avatar
Try flashing with the motor idling. Only thing it does is shuts the motor off.
Old Feb 26, 2010 | 09:41 AM
fostytou's Avatar
EvoM Community Team
Uhhhh...
Originally Posted by silex
....low voltage battery (started the car and tried connecting)
I wrote the book on it
Old Feb 26, 2010 | 11:14 AM
LGshow19's Avatar
Ummm, idk about this. Can you say "brick"?
Old Feb 26, 2010 | 11:54 AM
fostytou's Avatar
EvoM Community Team
You can, but you would be wrong.
As part of the flash code the motor is stopped, ECU goes into flash mode, and the flash begins.
Many times for people with weak batteries or ornery ECUs this is the only way to get a flash going without hooking up to a charger.
Old Feb 26, 2010 | 02:06 PM
Monochrome's Avatar
Uhhhh...
That you did.
Yes, I can say brick. Some people say I have a mid-western accent though and it sounds funny.
Old Feb 26, 2010 | 05:42 PM
LGshow19's Avatar
Good to know. Thanks for correcting me and giving good advice.
Old Feb 26, 2010 | 05:48 PM
LGshow19's Avatar
That you did.
Lol, my bad dude. Wasn't trying to make it seem like you were a Big dummy.
Old Feb 26, 2010 | 06:37 PM
Monochrome's Avatar
No worries man.
Old Feb 26, 2010 | 09:27 PM
LGshow19's Avatar
word...
Old Feb 26, 2010 | 09:28 PM
LGshow19's Avatar
So you find out whats wrong?
Old Feb 27, 2010 | 10:51 PM
silex's Avatar
I appreciate the help guys. This is why I decided to keep the car and stay in the Evo family
I forgot to mention this, but this was the first thing I tried and it did not work. Then again, the battery was "dead" at the time so hooking up the battery might not have gotten it juiced up enough. The battery now starts the car on its own after trickle charging it for a few nights so I might have to try this method out now with the charger in starter mode.
I will try fostytou's suggestion, but other than the above I have no other clue.
Old Feb 28, 2010 | 01:57 AM
evoredy's Avatar
since i haven't been back in the states for a while, i haven't dove into this issue (or anything evo related lol) at all--but--flashing in EVOSCAN always works when i have your issue. seems like ECUFLASH times out/doesn't init for one reason or another.
actually, EVOSCAN has never failed on a flash attempt for me.
just some food for thought...i know you may not have that option as EVOSCAN is not free.
the fix may already have been covered here.
if you have or have a friend with EVOSCAN, try it out. you guys will probably figure it out before i get back.
