Fuel maps don't line up?
Seijuro,
Just in case you missed my comment, your findings are most likely due to lean spool. Do you have that enabled? Your AFRMAP compared to your mapped values are exactly in line with the leanspool mappings.
That's what I suspected, thanks for clearing it up.
It raises another question for me though. MUT02 and MUT03 are used for 2Byte RPM. Similarly MUT04 and MUT05 are used for 2Byte Airflow.
Are there any cells in the MUT that basically aren't used? Or will I just need to give up one thing to log another?
Better yet because I'd rather know how to fish than eat a fish, where would I find all the uses of the MUT currently?
I have no other choice but eculod with my current ecu. The timing map seems to follow it precislyy since when e ee I adjust timing for knock it reflects my changes fine. But my fuel map is a different story
If you have already gone down this path and gathered all the answers, I would encourage you to create such a repository for the sake of the community.
I would be happy to do it myself, but I'm still in the learning process.
Thank you however for your concise explanation on how to bring the data to the MUT table, and subsequently how to configure EvoScan to then retrieve it. I have not (yet) found that anywhere else, so at least it exists here now.
Prior to this thread I'd read references to the "MUT table" plenty of times before, but I did not see definitions to questions like "What is the MUT table?" and "What purpose does the MUT table serve?"
I have a better grasp on those things now.
FWIW I still don't know what the MUT acronym actually stands for, although I have a feeling the phrase MUT table is redundant much like the phrase ATM Machine.
I found this page before, and actually left it up in a tab. It didn't "click" for me that it was the answer to my question until you slapped me across the face with it.
So now that I'm home and I'm going over my Rom in EcuFlash, is there another name for lean spool? I have a "Boost Enhancement (Anti-lag) start RPM" and "... stop RPM respectively.
Is this my lean spool?
Start is 2500 RPM and stop is 4531 RPM.
To be complete, I can set the start RPM higher than the stop RPM to disable it? Or is it better to set the start RPM above my real world shift point?
Give me a second and I'll paste all of the XML defs for lean spool for you to take a look at. The tables you metnioned aren't the lean spool tables.
To disable lean spool, the easiest way is using the periphery bit, but you can use the start and stop RPM.
Or, as another option, you can keep lean spool on and tune for it's effects or even tweak it if you would like.
PHP Code:
<table name="Lean Spool Start RPM" category="Misc" address="1680" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="Lean Spool Stop RPM" category="Misc" address="1684" type="1D" level="1" scaling="RPMStatLimit"/>
<table name="Lean Spool Load Threshold" category="Misc" address="39a2" type="2D" level="1" scaling="Load8">
<table name="input value" address="684a" type="X Axis" elements="14" scaling="RPM"/>
</table>
<table name="Lean Spool Trailing Time (Rich Side)" category="Misc" address="397a" type="2D" level="1" scaling="uint8">
</table>
<table name="Lean Spool Trailing Time (Lean Side)" category="Misc" address="398e" type="2D" level="1" scaling="uint8">
</table>
<table name="Min Temp for Lean Spool" category="Misc" address="167e" type="1D" level="1" scaling="Temp"/>
<table name="Lean Spool Enable Load Hysteresis" category="Misc" address="167c" type="1D" level="1" scaling="Load16"/>
<table name="Lean Spool AFR Mapping" category="Misc" address="39b6" type="2D" level="1" scaling="AFR">
<table name="base AFR" address="6870" type="X Axis" elements="7" scaling="AFR16"/>
</table>
<table name="Lean Spool AFR below Enable" category="Misc" address="1682" type="1D" level="1" scaling="AFR16"/>
<table name="Lean Spool Clip Value" category="Misc" address="1686" type="1D" level="1" scaling="AFR16"/>
EDIT: ok. that's stupid the profanity filter edited the url. replae *** with a four letter word for poop.
Scroll down and read about MUTIII. We call the protocol "mut" because it's meant to be used with that tool.
d
PHP Code:
</table>
</table>
</table>
</table>
Looks like I have more work cut out for me.
I have a couple different 96530006.xml files
Depending on which one I drop in to my rommetadata folder, I either do or don't have Periphery bits.
It appears that Periphery bits come from the base file. In my XML files where Periphery bits display in EcuFlash, they read; <include>evo7base_20081101</include>
In my XML files where Periphery bits don't display, they read
<include>evo7base</include>
I'm not sure what that's about. I think it may be due to version difference. I use a newer version of EcuFlash to edit, but I'm relegated to an older version for flashing.
EDIT: I found code very similar to what you have above in my evo7base_20081101.xml file. I modified my 96530006.xml to include evo7base_20081101, and now when I open it in EcuFlash there is a "Fuel Lean Spool" statement under Current Rom Metadata, however it is not expandable. Hmm.
DOUBLE EDIT: Okay, it looks like the base file lays out the framework for the metadata "tree". The definition file fills out the details within that tree of where the data can be found on the ROM, and how it should be displayed to the user.
So, although I have the tree built for lean spool in the base, none of the details are there in my definition file.
The code you posted should be then that 2nd half that I'm missing, but I've gotten the impression that addresses vary from ROM to ROM. What ROM version is that from?
If you've got lean spool going on though, that's too many uncharted variables to work with. I'd disable it until you are able to log corrected load.
Thanks man. My car isn't turboed factory so lean spool isn't available anyways along with anything else in regards to the turbo. So is 10.01 the max low the afrmap will read? Be ause e ery pull I did the afr. Stopped dropping at ten arund 3000 rpms then stays there until I redline and let off the throttle.
I'm pretty sure you can safely go by just the high octane map if you don't have knock. If you do have knock, the computer is going to start to blend the high and low octane maps.
That's why I have my high octane and low octane maps equal, for now, to cut out that variable.
So that said, can you post up a screen shot of your fuel table and a graph of your pull?
Man am I ever catching hell with these .xml files.
Now stuff is missing, like Injector Size scaling.
EDIT: Okay I see what's going on. Since I changed the definition file to reference a different base file, the table names don't always align.
In the base file it's "Injector Size Scaling". In the definition file, it's "Injector Scaling".
I guess that's my lesson in thinking you can take data from two different software versions and smush them together without bugs.
