My a/f gauge messed up.....
Old Mar 7, 2010 | 09:56 PM
eXtreme-Speed's Avatar
Ok so i am trying to tune my car today and have noticed on evo scan that my a/f ratio reads differently. Like for example it used to say 14.2 now it says 4.2?? WTF! so i was like ok no big deal i guess that just means I'll add 10 and make it 14.25 lol.
When reviewing the logs of my a/f ratio i realized on WOT it was at 14.23 the whole time...
So i decided to take the car back out and log the a/f and watch my gauge while i went WOT, cautiously of course . So i was seeing that my gauge in the car was reading like a 12.8 on WOT and evoscan was reading like 14.23 WTF is that??
The purpose of this was because i was trying to tune for 11.4 a/f.. So i used the data from evo scan and tap the gas a little with the changes and realized my gauge was reading like 8. something so i just stopped cause i don't feel like having a blown motor.
Can anyone help on this little issue? thanks!
BTW it's a inovate lc-1 with a digital blue gauge and evoscan is connected threw the serial port.
Old Mar 8, 2010 | 01:25 PM
SoCal Rally's Avatar
I think the Innovate wideband AFR system needs to be calibrated at regular intervals, which is why some people don't like it.
Old Mar 8, 2010 | 01:55 PM
That's what i am going to try and do today.. That's so beat.. Thanks. I'll report back in a little
Old Mar 8, 2010 | 02:55 PM
THUB's Avatar
Is it possible you grounded the calibration wire by accident? That would definitely cause some weird readings. Were you logging your nbo2 sensor also? It's not good for actually tuning, but it could be useful in diagnosing your problem.
Old Mar 8, 2010 | 03:05 PM
Psquared's Avatar
One thing to be careful of...Don't unplug any cable from your wideband with power going to it. For example, if you have it wired to come on with your key turned "on" don't unplug any cables while it's powered on. It somehow messes up the settings within the LC-1. Mine did this same thing, when I checked the internal settings of the LC-1 it reverted to reading Alcohol. It's an easy fix if that's what happened. Otherwise, calibrating wouldn't hurt at all.
5LEEPERISAH23I
Apr 18, 2010 06:48 PM
rdtech
Oct 4, 2009 08:25 PM
Usedcarfinders
11
Oct 10, 2007 02:26 PM
BCOZEVO
Sep 30, 2007 12:25 PM
AlwaysinBoost
38
Sep 11, 2005 07:15 PM
