Grimspeed BCS help!!!
We can't really help you unless you post up some logs. I would recommend you to post a log when you had your MBC and a log with your 3-Port. By the way, how are you logging boost? With a MAP sensor, or a boost gauge?
Sorry I didnt post any logs.....but I figured out the issue, since the 3port hits sooner, the load vs RPM tables are all different now. With the MBC I would hit 120 load at 3300 rpm, now with the 3 port I hit 160 load at the same rpm, now my tune is shifted and at all points the car is both richer and there is less timing meaning less power right...Im adjusting it as we speak maybe I'll test it tomorrow.
Cwill taught me how to tune a little bit so, I'll try to make adjustments to the Timing and fuel map myself see where I can get it to
Here's the log, the car was heatsoaked so it started to knock a little(2 counts) at redline, that was my 8th pull in a row logging to adjust the WGDC though.
Ok so here are my Load settings with a log, how do I get it to hit the load and boost from above? (330 load all around and 27-28psi till redline) on the log above the TBEC table was zeroed out and my load settings were different.
Just post up the EvoScan log .csv file. You have too many parameters enabled in the Data Graphing, which makes it hard to make out important data that we need to see to help you. I must say with no offense that your way of tuning boost is quite weird.
Any quick help I can get is fine, I'm trying to hit the track tomorrow to see how the car is running, can i just leave the TBEC zeroed out, I know its not the right way to do it but im kinda confused on the whole load thing. Thanks guys
You are logging too many parameters that are not needed thus slowing down the EvoScan logger. Just only log the following parameters, and place it in the following order to make it easier on you to tune; Throttle Position, Engine RPM, Load, OMNI, Timing Advanced, Knock Sum, Wastegate Duty Cycle, Load Error (optional), WGDC Correction (optional), and External Wideband (if you have one). The 'optional' parameters don't have to be logged until you are adjusting the Boost Desired Engine Load(BDEL). As for the logs you have provided, they are pretty useless since you did not log WGDC and I have no way of knowing what WGDC% you are running at certain boost pressure on a particular RPM.
It is not really recommended to run with TBEC zeroed out, but if you must - you can. I would just recommend doing a couple of logs before hand, while going through the gears. [ie. Log WOT: 1st to 2nd to 3rd to 4th(if possible) and see if you are overboosting]
My car has been in Miami for that month now, I got a Tripple Disk installed and im getting the car soon because I've been busy and unable to pick it up. As of right now I need to make a log with WGDC which I havent done, I'll post it up in a couple days. Thanks for checking back bro, I appreciate it
FS[Northeast]: 2015 Evo X FE #129 with 10,xxx miles
lufu
For Sale - Cars For Sale
Jun 26, 2017 12:38 PM
JScocchio
Sep 28, 2011 11:20 PM
