map needed for cammed evo
Old Mar 15, 2010 | 03:09 PM
tim85851's Avatar
Nvm.
Old Mar 15, 2010 | 03:16 PM
tim85851's Avatar
my current flash has o2 simulator if thats needed...i think i basically need fuel and timing map...
what should idle be set at?
Old Mar 15, 2010 | 03:19 PM
EVO_MERLE's Avatar
i was able to drive mine fine after i put in the S2's..just stay out of boost as much as possible and play with your idle got mine at 750 i think
Old Mar 15, 2010 | 04:14 PM
tim85851's Avatar
anyone with kelfords and close to the same mods want to email me their current map please?
tim_viii_ix@yahoo.com
Old Mar 15, 2010 | 04:15 PM
EvoDan2004's Avatar
if your getting it tuned why dont you ask your tuner for the base map?
Old Mar 15, 2010 | 07:24 PM
Seijuro's Avatar
Are you still running MAF? Have you tried running the car yet?
If you're still running MAF, you'll pretty much be ok. That's one of the perks of MAF.
More timing at idle will help if it's stumbling. If the idle vibration is annoying, you can raise the target idle RPM up until you like it. 850 - 900 would probably be smooth.
But I'll also say, drive gently until it's tuned in.
Old Mar 15, 2010 | 09:11 PM
tim85851's Avatar
thanks guys...more suggestions? or does anyone have close to same mods to send me their map?
