Maf compensation help
Old Mar 18, 2010 | 02:21 PM
jdmevo123's Avatar
Hi all,
I need help with my maf compensation table. I have attached logs. I have a gruppe m air intake installed and I am unsure of how to tune the Maf compensation table. I currently have the standard evo 8 Maf compensation on tephra v7 rom.
Any help will be appreciated.
Thanks
Dale
File Type: zip
Old Mar 18, 2010 | 03:41 PM
Jorge T's Avatar
You really should not need to do much unless you changed to a metal/aluminum turbo inlet pipe. I run a mishimoto intake (modified to work similar to the gruppe m) and only increased the 19 and 25 hz settings to get the idle in check.
But before you mess with the maf make sure your injector scaling and injector voltage compensation are in check. Your idle log shows afr in the 11s so I'm not sure what is going on there.
Also when logging, log less items to increase the samples per second.
Old Mar 18, 2010 | 04:17 PM
jdmevo123's Avatar
Thanks,
How do I make sure my injector scaling and injector voltage compensation are in check? I have just moved over to V7 and finding it hard to get everything working correctly. Help on this would be appreciated.
domyz
Sep 3, 2014 08:14 PM
Ceddy
May 17, 2010 04:11 AM
simple_lancer
Sep 22, 2009 07:57 PM
jcsbanks
Feb 2, 2009 01:25 AM
mrfred
Sep 30, 2008 01:31 PM
