Ignition Map Load Adder? MrFred?
Old May 16, 2010 | 03:56 PM
Ceddy's Avatar
I am looking at the Ignition Map Load Calc sub on the H8s.
I know MrFred has posted the the Load Decision before, LoadIATBaro if Air Temp > 77*F, else LoadBaro.
But there seems to be two Compensation tables that are added to the above Load.
I was wondering if the Evos also have this Compensation?
And what the Compensation tables axis are? (Axis lookup is hidden in H8s)
The math is a little funky, but it looks like these Compensations could have a significant effect on final Ignition Map Load.
Thanks much for any info.
Edit:
The first Comp table is used when MAF is unplugged or the car isn't running, I think.
But, the second table is for normal use and has high compensation at is top end.
Old May 16, 2010 | 10:20 PM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Edit:
Can you specify locations in H8?
Old May 16, 2010 | 10:49 PM
Ceddy's Avatar
20550011
IgnMapLookUp
calls->LoadCompAdder
--------calls->LoadDecision
IgnMapLoad = LoadDecision + LoadCompAdder
IgnMapLookUp = 26086
LoadCompAdder = 261B3
LoadDecision = 26208
CompTable_Limp/NotStarted? = 2EC90 Points to 12628
CompTable_Normal = 1261A
Do the SH ecus have something similar?
Old May 16, 2010 | 11:04 PM
acamus's Avatar
Yes, but only in Evo9
The map does IAT LOAD compensation.
Load is either Baro compensated or Baro and IAT compensated (10E58 limit in your case)
Evo 9 uses RPM based compensation.
Old May 17, 2010 | 12:41 AM
Ceddy's Avatar
Yes, but only in Evo7/8
So that map is a IAT compensation?
So basically at high temps the Load is compensated twice for IAT?
(Once from the table and once because its LoadIATBaro)
[And the Lookup is thirdly compensated by "Ignition Trim vs Air Temp"]
I ask because I'm changing things for my new version of "BigMaps".
Making Fuel and Ignition maps same size and use the same Load, for easier, more consistent tuning and logging.
I think if I use LoadIATBaro all the time for both maps it will be ok, but want to make sure the Comp table isn't necessary for safety or something.
Old May 17, 2010 | 01:10 AM
acamus's Avatar
I do not see your point
In 26208 depending on 10E38 either Baro compensated or baro and IAT compensated load is taken.
Old May 17, 2010 | 02:00 AM
Ceddy's Avatar
1261A is either Warmup ignition trim or EGR ignition trim.
I thought you meant 1261A was a IAT Comp.
Its not WarmUp, that has its own 3D map.
And it modifys the axis Load, not like a normal ignition trim.
In 26208 Load decision is based on:
mov:g.w @AirTmp$_F22A:16, r0
cmp:g.w @word_E58:16, r0
(E58=0x41=77*F)
Maybe we're looking at different things.
Old May 17, 2010 | 03:27 AM
acamus's Avatar
Yes, probably I have misunderstood it Or I have had insufficient coffee level
It is similar to IX.
Just the value in IX (88590015@134A = 0 in IX) makes this adder as not used, 20550011@A24 = 7 in your case is different thou.
So for 88590015 LoadCompAdder @ 1BC6C
RPM Axis
@6B70
Tables
@3C6A,@3C5A
Old May 17, 2010 | 04:11 AM
Ceddy's Avatar
In the H8s this appears to be a Tip-In Compensation.
A24 = 7 is multiplied by a TPS_Delta, then that is multiplied by the 1261A table.
Only the high word is kept and is added to the Load used for Ignition map lookup.
So if there is a large TPS change, Load is increased, and as a result Timing is decreased because you are higher up in the map.
Kind of a round about way of doing it, but it probably produces a better Timing Compensation.
Thanks for the Evo9 addresses. I was trying to find it in the Evo roms with no luck.
l2r99gst
Jul 7, 2017 10:51 PM
PPM
Apr 2, 2015 09:35 AM
mrfred
Dec 21, 2014 10:13 AM
Seijuro
Mar 20, 2010 11:53 AM
mrfred
Sep 30, 2008 01:31 PM
