About adding MUT Table to EcuFlash?
Old Apr 21, 2010 | 11:19 AM
5LEEPERISAH23I's Avatar
I added a MUT table to EcuFlash for ROM 96170015. Listened to the step and successfully got it to show up on EcuFlash.. I added in the RPM , LOAD, address after u bring up the MUT table in EcuFlash n put them in the proper places the 2bite threads says to put it in..
My question is, When i run EvoScan with that ROM ID "96170015" it should be perfectly fine with the changes i just made or do i have to do something in EvoScan now for it to adapt to what i just changed in the MUT table?
Old May 16, 2010 | 08:27 PM
!Ev0$'s Avatar
Old May 17, 2010 | 09:54 AM
Raptord's Avatar
You need to put a checkmark next to the 2byte data you want to log in Evoscan. If the adresses you input in EcuFLash are different from the ones in Evoscan for that same data source, you'll need to change the one in Evoscan to match it. WHen I get home I'll be able to give better help if need be.
Good luck!
mrfred
May 1, 2020 10:16 AM
neuralcj
Jan 7, 2018 02:50 PM
Cbr1000love
Jan 31, 2016 05:01 PM
EvolNinja
May 27, 2010 05:00 PM
EvolutinIX
Apr 1, 2010 05:48 PM
