Evoscan/tephra v7...
Old Mar 20, 2010 | 11:57 AM
BillSpec's Avatar
Exclamation Evoscan/tephra v7...
I normally wouldnt make a thread about this, without searching a bit more...
But thats what threads are for right?...
While logging with evoscan, I make a pull in third to about 8550 rpm...
Evoscan only shows me 7986.... then it stops...? What gives? I keep thinking 2byte rpm or something like that has to be the culpret...
Thanks in advance fellas
Old Mar 20, 2010 | 01:00 PM
l2r99gst's Avatar
That's the limit for 1byte RPM.
Old Mar 21, 2010 | 11:14 AM
BillSpec's Avatar
God i am such an idiot... lol i knew it
hmmm.... just went to the v7 thread and i read this under the mut requests...
Preconfigured MUT Requests
MUT00+MUT01 = 2byte airflow (ie MrFreds mod in g/s or lb/min)
MUT02+MUT03 = 2byte airflow (ie MAFHz)
MUT40 = 1byte gear
MUT41 = 1byte load
MUT42+MUT43 = 2byte SPEED/RPM ratio (to get your gear ratios correct - if you need to)
2byte load AND 2byte RPM are no longer included and IMHO not needed!
So do i have to repatch my rom for 2byte?
Old Mar 21, 2010 | 11:42 AM
l2r99gst's Avatar
Yeah, if you want to log 2-byte RPM and are using EvoScan, then you have to setup to MUT entries with the two variables, then setup EvoScan to log them.
If you're using LiveMap, then just put those two variables in your RAM MUT table and setup LiveMap to log them.
Old Mar 21, 2010 | 12:08 PM
BillSpec's Avatar
I figured... thanks mang...
did you shoot me that 885 dma?
Old Mar 21, 2010 | 12:14 PM
l2r99gst's Avatar
It's in your inbox.
Old Mar 21, 2010 | 02:07 PM
BillSpec's Avatar
Originally Posted by l2r99gst
It's in your inbox.
Rpf1evolution
Oct 14, 2013 08:03 AM
OneEyedJack
Sep 15, 2010 01:10 PM
5LEEPERISAH23I
Jun 15, 2010 03:40 AM
Appauldd
Mar 31, 2009 09:22 PM
KS_Evo9
Oct 26, 2007 09:30 AM
