Fuel Trim Issue(s)
Old Mar 22, 2010 | 09:57 PM
THUB's Avatar
Fuel Trim Issue(s)
I'm having a problem with getting my injectors scaled. I have GSC 280 cams and a 10:1 compression engine. It's running E78 right now (winter blend). At idle I see high 20's (27-29 usually) for 1 byte load at about 1250 RPM, the idle is absurdly stable for such big duration cams also. I blame this on the high compression
The LTFT mid is adjusting as expected consistently, given straight smooth highway driving, however I can't say the same for the LTFT low. Sometimes it will adjust, sometimes it wont, given similar changes in scaling and latency values. I'm wondering what the criteria for adjusting the LTFT low is in the ECU, as my V7 definition has something wrong with the values. I can see the table is there, but there are no values in it. Can someone help me out with this? I'm using the XML file for 94170715 with the appropriate rom from tephra's thread.
Old Mar 23, 2010 | 06:05 AM
Appauldd's Avatar
Log what Ariflow Hz you are at idle. Your issue could be that because you are idling so high (rpm) that you are not in the Hz range for the LTFT low to adjust.
Find the "Closed Loop-LT Trim Control" table in the Global Fuel Settings.
The table will show the crossover points for the various MAF Hz reading. Make the following changes....
Low -> Mid = 62.50
Mid -> Low = 50.00
This should allow you enough room at idle for the LTFT Low to adjust.
Old Mar 23, 2010 | 08:31 AM
THUB's Avatar
In my computer those tables are undefined. Could this be because I'm using too old a version of ecuflash?
Old Mar 23, 2010 | 09:56 AM
Appauldd's Avatar
What Rom version are you using?
Old Mar 23, 2010 | 11:12 AM
THUB's Avatar
94170715 non speed density, no live map. When I get home. I'll post a screenshot of my tables.
Old Mar 23, 2010 | 11:22 AM
Appauldd's Avatar
OK You have the latest rom version so the table should be in there. If it isn't please let me know. I will send you the XML you would need to see the table I speak of.
Paul
Old Mar 23, 2010 | 02:35 PM
THUB's Avatar
I was behind a version of the actual ECUflash software. I didn't know this made a difference. Once I loaded the new version, I was able to see and actually edit the table you were talking about. I could see it in the older version, but could not see any values next to the words. I should be fine now. Thanks a lot.
Old Mar 25, 2010 | 08:32 PM
NCarrillo's Avatar
Could you send me that xml bec i don't have that table. I'm running rom 94170008.
Old Mar 26, 2010 | 09:27 AM
Appauldd's Avatar
0008 isn't supported sorry. Upgrade to 94170015.
AlwaysinBoost
Sep 23, 2010 12:30 PM
charlie.tunah
Jul 13, 2010 02:24 PM
LaXGSR
14
Apr 7, 2010 08:09 AM
