Can't flash or read the ROM from your ECU - Start Here!
Old Jan 3, 2011 | 01:51 PM
SWOLN's Avatar
Battery voltage was too low, charged it up after reading this thread, and we were golden. Thanks for the Sticky!
Old Apr 5, 2011 | 12:59 PM
fasterbater's Avatar
This thread just remedied much head-scratching, thanks to the OP!
Old Apr 20, 2011 | 03:16 PM
PBAYEH's Avatar
Cannot Read From EVO x GSR with SST
I read mainly all exesting threads on evolutionm and other websites to see what my problem was and tried everything with No Luck.
I live in Doha, Qatar. I got a brand new 2009 EVO X with SST Gearbox. It has only 10K on it and never been tuned, also never been services outside the dealer.
I got the Openport 2 from Tactrix and the Evoscan software. it is working fine and was able to log all the data.
But when i tried downloading the ROM on my laptop using ECUFLASH i always got unknow error.
At first it says that it was locked and i used the unlocker. Now it is not saying that it is locked anymore and still have the unknow error.
Saw your thread about bad connections, low battery voltage and all of that, and did everything mentioned there and still have the same issue.
I did a print screen for the log if you can take a look at it and tell me what the problem is.
[19:09:57.915] EcuFlash Version 1.42.2595
[19:09:57.915] OS Version Windows Vista
[19:09:57.915] Qt Version 4.5.0
[19:09:57.931] 56 memory models read.
[19:09:57.931] scanning for metadata models in C:/Users/DXBBAYEHP/Documents/EcuFlash/rommetadata
[19:09:59.054] 82 ROM metadata models scanned.
[19:09:59.054] checksum module "subarudbw" loaded.
[19:09:59.054] checksum module "mitsucan" loaded.
[19:09:59.054] flashing tool "wrx02" loaded.
[19:09:59.054] flashing tool "wrx04" loaded.
[19:09:59.070] flashing tool "sti04" loaded.
[19:09:59.070] flashing tool "sti05" loaded.
[19:09:59.070] flashing tool "mitsukernel" loaded.
[19:09:59.070] flashing tool "mitsukernelocp" loaded.
[19:09:59.070] flashing tool "mitsubootloader" loaded.
[19:09:59.070] flashing tool "shbootmode" loaded.
[19:09:59.101] flashing tool "shaudmode" loaded.
[19:09:59.101] flashing tool "subarucan" loaded.
[19:09:59.101] flashing tool "mitsucan" loaded.
[19:10:16.838] J2534 API Version: 04.04
[19:10:16.838] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[19:10:16.838] Device Firmware Version: 1.10.3020
[19:10:20.001] -- loading kernel --
[19:10:20.001] -- connecting to kernel --
[19:10:20.001] kernel get version
[19:10:20.344] ECU HW part number : 1860A982
[19:10:20.375] ECU SW part number : 1860A98201
[19:10:20.391] VIN : JE3AE86V89U720086
[19:10:20.391] -- unlocking ECU --
[19:10:20.391] starting session...
[19:10:20.407] requesting seed...
[19:10:20.407] interface close
[19:10:20.453] interface close
Thank you and i appreciate your help.
Old Aug 17, 2011 | 08:13 AM
sawgunner06's Avatar
Post Having same problem
I have tried everything and no luck getting my ROM to pull up on ECU Flash... For some reason I am trying to dowmload the unlocker but it will not let me do so.. Anyonr have a couple sites I can use.
Old Aug 17, 2011 | 11:34 AM
marknasr's Avatar
i have tried the mitsulogger - ecu unlocker along with the ecuflash yet i cant read my ecu map .. anyone has any idea abt tht ?
Old Sep 24, 2011 | 01:00 PM
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
It sort of looks like Mitsulogger / ECU unlocker doesn't work with openport 2.0 - is that right?
Old Dec 28, 2011 | 07:12 AM
Butt Dyno's Avatar
Ignore this
I didn't have the ECU reflash connector. I thought that you only needed that to write the ECU, but you need it to read the ECU too.
Once I used the reflash connector it worked fine.
Old Dec 28, 2011 | 05:00 PM
minezevoix's Avatar
Sorry noob question but I tried to read my ecu today using ecuflash and when I appeared to be locked out of it I downloaded the ecu unlocker(which I am unsure if this is running correctly but this is as far as I get:
[19:54:36.232] EcuFlash Version 1.43.3252
[19:54:36.232] OS Version Windows 7
[19:54:36.232] Qt Version 4.6.2
[19:54:36.243] 62 memory models read.
[19:54:36.244] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash
[19:54:42.040] 1426 ROM metadata models scanned.
[19:54:42.040] checksum module "subarudbw" loaded.
[19:54:42.040] checksum module "mitsucan" loaded.
[19:54:42.040] checksum module "mitsuh8" loaded.
[19:54:42.040] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[19:54:42.040] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[19:54:42.041] flashing tool "wrx02" loaded.
[19:54:42.041] flashing tool "wrx04" loaded.
[19:54:42.042] flashing tool "sti04" loaded.
[19:54:42.042] flashing tool "sti05" loaded.
[19:54:42.042] flashing tool "mitsukernel" loaded.
[19:54:42.042] flashing tool "mitsukernelocp" loaded.
[19:54:42.042] flashing tool "mitsubootloader" loaded.
[19:54:42.042] flashing tool "shbootmode" loaded.
[19:54:42.044] flashing tool "shaudmode" loaded.
[19:54:42.045] flashing tool "subarucan" loaded.
[19:54:42.045] flashing tool "subarucand" loaded.
[19:54:42.045] flashing tool "mitsucan" loaded.
[19:54:48.781] Using interface OpenPort 1.3 Universal TX2EdH#L5e8074c541868b2b97c1895b02b2244094c2d3cf
[19:54:51.525] sending init sequence 1 (0001)
[19:54:54.764] sending init sequence 1 (0003)
[19:54:58.020] sending init sequence 1 (FFFF)
[19:55:01.259] sending init sequence 1 (F0F0)
[19:55:03.991] no response to any known code
[19:55:03.992] interface close
Any ideas? Battery voltage is 12.4 volts with the key off and 12.2 volts with the key in the on position.
Old Dec 30, 2011 | 01:53 PM
minezevoix's Avatar
After starting my car and letting it idle for a few minutes I was able to read the rom. Voltage must be a touchy issue when trying to read the ecu.
Old Jan 7, 2012 | 07:15 PM
mace1890's Avatar
im getting the no response to any known code but i have two ecu's and the first one gave me this code so i switched ecu's and the second one worked fine for a few flashes then after that i got the code with the second one too i dont know whats wrong im charging my battery right now to see if thats it but it doesnt make sense that one stops working and the second one works fine for awhile
Old Jan 9, 2012 | 11:10 PM
gotpsi?'s Avatar
Ive got a weird issue, When I run ECU flash in the 1.42 version I can open and edit my tunes, but I cannot read or flash. If I run the 1.43 version I can read and flash but I cannot edit the tune or ecu flash crashes. Any Ideas?
Old Jan 26, 2012 | 04:19 PM
alexlewand's Avatar
good question, same here. 1.3 cable, I can read and write in 1.29 Ecu Flash but edit all options only in 1.42 they both have same definitions for my Tephra V7 etc.
weird...
Old Mar 20, 2012 | 07:27 AM
Harismr8's Avatar
Can't flash or read the ROM from your ECU - Start Here!-ignition-map-copy.jpg
hi....
I have two problems with ecu flash and my tuning stay freeze.
First the pop up window with vehicle type is empty.
Second I download the ecu image with other laptop but when i open the image with ecu flash some values are 'I think' are not correct. Take a look on rpm and load engine values.
RPM: 395, 461, 2559.., 1364.., 2559...,1406..., 105, 0, 39,78,117,156,195,234,273.
LOAD: 41,43,47,50,53,56,59,62,66,69,72,74,78,80,204...,1 09...,204...,112...
ecu id: 96260007
Thanks Haris.
Old May 5, 2012 | 04:54 PM
steveyrich's Avatar
I'm having an issue with reading rom with EcuFlash. I have literally tried everything. I'm using OpenPort 2.0 cable. EcuFlash 1.42.2595.
Sends the 4 init codes and then fails. I've tried using the AktiveMatrix ecu unlocker to no avail. I'm not sure if it is even working? I know it just pops open a window, but can anyone verify that perhaps it doesn't work with Win7? I've tried several different versions of EcuFlash, old and new. Also tried logging with EvoScan for the hell of it. Nothing connects. Checked the pins on the ecu, all good. Battery voltage is fine, I even hooked up a battery charger to the car to rule it out. All accessories are turned off. Tried every possible sequence of starting the unlocker program, then ecuflash, then turn the key on, etc. etc.
Also, I'm unable to start the car, it just cranks. I'm leaning towards it being something physically wrong with the board in the ECU. I bought it from a member on here so I don't know the background on it, not going to name names because I'm not blaming the seller, just trying to figure out if this ECU is going to work and go from there.
This *is* an ecu from a 2004, I'm trying to use it in a 2005 but I don't think that should matter, I just want to read the rom, save it and flash a universal tephra rom on it.
To top it off, I have ruled out my hardware 99.9% of the way. My laptop, ecuflash, evoscan, cable, etc. all work fine in my car, just when swapping in this ecu is when things don't work. I've tried this ecu in 2 different cars(both 2005 evos), neither one will allow ecuflash to read the rom or get the car to start.
Anybody have any ideas before I go and build a damn bench so I can bench test this thing and maybe try to fix/flash the rom in the ecu that way?
Old Jun 16, 2012 | 07:51 AM
FroZenEvo666888's Avatar
Actually I have tried to read the ecu when the car was running too...and with the ecu-unlocker running at the same time. I have tactrix 2.0 cable, and cannot read the ROM whatever.
Before running the ecu unlocker the code is this:
[10:27:22.859] EcuFlash Version 1.43.3150
[10:27:22.859] OS Version Windows XP
[10:27:22.859] Qt Version 4.6.2
[10:27:22.875] 62 memory models read.
[10:27:22.890] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[10:27:28.359] 354 ROM metadata models scanned.
[10:27:28.359] checksum module "subarudbw" loaded.
[10:27:28.359] checksum module "mitsucan" loaded.
[10:27:28.359] checksum module "mitsuh8" loaded.
[10:27:28.359] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[10:27:28.359] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[10:27:28.359] flashing tool "wrx02" loaded.
[10:27:28.359] flashing tool "wrx04" loaded.
[10:27:28.359] flashing tool "sti04" loaded.
[10:27:28.359] flashing tool "sti05" loaded.
[10:27:28.359] flashing tool "mitsukernel" loaded.
[10:27:28.359] flashing tool "mitsukernelocp" loaded.
[10:27:28.359] flashing tool "mitsubootloader" loaded.
[10:27:28.359] flashing tool "shbootmode" loaded.
[10:27:28.468] flashing tool "shaudmode" loaded.
[10:27:28.468] flashing tool "subarucan" loaded.
[10:27:28.468] flashing tool "mitsucan" loaded.
[10:29:49.593] J2534 API Version: 04.04
[10:29:49.593] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[10:29:49.593] Device Firmware Version: 1.11.3298
[10:29:49.593] Device Serial Number: TA1dwTKq
[10:29:53.296] sending init sequence 1 (0001)
[10:29:56.515] sending init sequence 1 (0003)
[10:29:59.734] sending init sequence 1 (FFFF)
[10:30:02.437] no response to any known code
[10:30:02.437] interface close
Then I run the unlocker with it, and it send out one more code F0F0. However still the same result:
[10:31:02.812] J2534 API Version: 04.04
[10:31:02.812] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[10:31:02.812] Device Firmware Version: 1.11.3298
[10:31:02.812] Device Serial Number: TA1dwTKq
[10:31:18.109] sending init sequence 1 (0001)
[10:31:21.312] sending init sequence 1 (0003)
[10:31:24.546] sending init sequence 1 (FFFF)
[10:31:27.765] sending init sequence 1 (F0F0)
[10:31:30.468] no response to any known code
[10:31:30.468] interface close.
Please help. Also can someone tell me do you also have to plug in another little white plug besides the main port itself? I have this optional port for evo 9, dont know what to do with it.
